Author Topic: XL250S con rod  (Read 3082 times)
Offline pmc57
XL250S con rod
« on: November 23, 2008, 09:22:14 pm »
I'm in hte throws of rebuilding an XL250S '81 model and may be needing a replacement con rod. Does anyone know where I can get one in the Brisbane area at a resonable price. I believe XR250 rods are the same, but not sure.
All feed back appreciated.
Re: XL250S con rod
« Reply #1 on: November 23, 2008, 09:24:50 pm »
go see a local dealer who buys parts from Bikes and Bits importers in WA. they have a large range of rods, pistons etc for most models. i will check tomorrow but i think they could do a rod. if not you just get them to fax you a rod chart, you then fill in the dimensions of your rod and fax it back and then they will match it up to a rod kit in their database.
will get you their ph/email tomorrow and they should be able to point out a dealer closest to you
« Last Edit: November 23, 2008, 09:29:07 pm by LWC3077 »
Offline jimson
  • Sanctuary point N.S.W
Re: XL250S con rod
« Reply #2 on: November 23, 2008, 09:39:16 pm »
If those blokes can't help maybe Aconahonda in N.Z I don't know if I spelt  that word right :-\ just google it.jimson
Re: XL250S con rod
« Reply #3 on: November 23, 2008, 09:42:22 pm »
took me a while but found they do have a website
http://www.bbimporters.com.au/
also try
http://www.bkperformance.com.au/
« Last Edit: November 23, 2008, 09:44:02 pm by LWC3077 »
Offline pmc57
Re: XL250S con rod
« Reply #4 on: November 23, 2008, 10:05:06 pm »
Thank's guys, I'll give both a go
