Author Topic: yz 465 primary gears /alignment  (Read 2141 times)
lms6201
« on: November 19, 2008, 09:08:05 pm »
 does anybody know if the 465 helical drive gears are flush or if the pinion is slightly below the clutch gear ? , mine fits up slightly lower which would make it flush on the inside (pinion is thinner than clutch gear) thanks
Offline caps 999
Re: yz 465 primary gears /alignment
« Reply #1 on: November 19, 2008, 09:29:54 pm »
that sounds about right but id check the micro fiche
MUGEN power
Offline TonyB
« Reply #2 on: November 20, 2008, 03:25:29 pm »
yep from memory mine was slightly resessed.
'Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways,totally worn out, shouting,  ' Holy sh!t... What a Ride!! ' '
lms6201
« Reply #3 on: November 20, 2008, 09:58:23 pm »
thanks people ,
