Author Topic: Which 250?  (Read 8774 times)
Re: Which 250?
« Reply #15 on: November 20, 2008, 06:33:50 pm »
Swap or  sale.
Doc
Re: Which 250?
« Reply #16 on: November 20, 2008, 08:29:34 pm »
you have a happy snap of the baby TS in question? :P
Re: Which 250?
« Reply #17 on: December 03, 2008, 09:14:01 pm »
 Doc ,I got it  ;) bled him down to $10 and a used Honda ct125 agi bike piston and rings........................Bloody 75 model what's the main differences to the 74 ?
and I do have another universal type Wasp sidecar frame hanging on the wall............. 8)
« Last Edit: December 03, 2008, 09:20:50 pm by Tim754 »
Doc
Re: Which 250?
« Reply #18 on: December 03, 2008, 09:41:50 pm »
Tim, I've a good use for the used CT125 piston/rings :P I've seen the little TS50 Gaucho beasty and a deal has been struck..almost :P biggest prob now is it just needs to find it's way home :D
main difference with the '75 model, lower shock mounts moved fwd is about it I believe. There might be more but that's the main contention :-\ nothing drastic but the early arm doesn't fit the '75 so break out the grinder and welder if you wanna go pre'75 ;)
« Last Edit: December 03, 2008, 09:43:23 pm by Doc »
Re: Which 250?
« Reply #19 on: December 03, 2008, 09:47:54 pm »
Doc if I go to SA soon (and that looks a big if at present) I may be able to get the little bugger to here only has to go due north then....
Re: Which 250?
« Reply #20 on: December 03, 2008, 11:41:16 pm »
jason - rocket frog is picking it up for you doc, you just got to get onto him to call me when he leaves, its back here now so he can collect from town - then home to newcastle.
« Last Edit: December 03, 2008, 11:45:00 pm by Freakshow »
Doc
Re: Which 250?
« Reply #21 on: December 04, 2008, 08:05:02 am »
yup..no worries Freaky and thanks Tim, Rocketfrog, bless his kind soul, will make the collection at his earliest convienience but the little bike will still need to find it's way up from Newcastle to stormy Brisvegas. Not far at all and so long as it keeps the pacific ocean on it's right then it'll be heading in the right direction ;D
Re: Which 250?
« Reply #22 on: December 08, 2008, 11:26:07 pm »
Dare I ask parts wanted for 1975 TM250, Carby and manifold  ,air filter assembly. plastic panels, rear guard assemble and tank.  ;) Cheers Tim
