Author Topic: PE 175  (Read 39569 times)
Re: PE 175
« Reply #30 on: November 14, 2008, 08:34:09 pm »
shocks dont appear original ;D or maybe you just have them unside down? i cant see clearly enough in your pic. rear fender???. have you got the perforated tank decals on it from motoduro? if so what do you think of them? how long have they lasted? any signs of bubbling?
« Last Edit: November 14, 2008, 08:36:40 pm by LWC3077 »
JC14
Re: PE 175
« Reply #31 on: November 14, 2008, 09:06:33 pm »
just out of curiousity, would a 400 motor fit in my frame? if so would it need to be strengthened? thanks
Re: PE 175
« Reply #32 on: November 14, 2008, 09:22:25 pm »
thats a tough one. a 250 will, but i think a 400 would be a bit too tight..cases would fit as they are same as they 250 basically, but you would struggle with the top end and the rest of it. with a 250 in a 175 floater the carby is allready a tight fit and the bigger barrel of the 400 would space the carburettor back further. nothing is impossible so i think someone with mechanical and welding skills could maybe do it,i think it could be a little too much power for that chassis too? but ive also heard of a RM 500 in a 125 frame aswell, so dont know? the other recommened mod is to then also fit a bigger rear rim  and tyre when fitting the 250 motor.
theres always a few PE 250 and 400's on ebay, maybe they would be a better option if you really want more power?  many expert enduro PE riders such as Geoff Udy (he still has a 400 and may be riding a few vinduros soon, so im told) have said the 80/81/82 twin shock PEs were better than the full floater rear on the 175 when the std twin shocks shocks were replaced with a good set of french DeCarbons or some Ohlins. the twin shock geometry on the later PE's was at the pinicle of twin shock design, and isnt all that bad.
« Last Edit: November 14, 2008, 09:29:26 pm by LWC3077 »
Offline frostype400
Re: PE 175
« Reply #33 on: November 14, 2008, 09:28:24 pm »
Hi Leith shocks arent original forgot to mention that  ;D rear fender is though just suffered trim years ago but its getting repainted again and i got sidecover stickers from Nick at Motoduro those tank ones are from him and are excellent the are extremely tough havent laid the bike over YET  :) but im sure they would'nt get hurt i spilt petrol on them never looked like bubbling if you're thinking about getting some they are very good i did need to give them a little trim with the stanley and straight edge but then just sprayed water on tank and positioned and are the same today as they were a year ago when i put them on just like the seatcover buy the way jc pretty sure Pe400 wont fit in your frame and doubt you would come across a 400 motor any way but the 175 and 250 were great i reckon you should stick with what you have by the way there are better photos on www.bikepics.com Thanks and good luck with your PE Michael Ryan :)
1971 tm400 and PE's
JC14
Re: PE 175
« Reply #34 on: November 14, 2008, 09:44:58 pm »
would the ful floater be better with a good shock in it? yer i didnt think the 400 motor would fit.
Re: PE 175
« Reply #35 on: November 14, 2008, 09:46:27 pm »
might have to try those perforated ones on a spare tank i have. i havent asked Nick yet but i suspect he gets MXM to make them. did you also get your seat cover from motoduro?
Re: PE 175
« Reply #36 on: November 14, 2008, 09:49:40 pm »
yeah should be. another good idea is to use the USA market full floater shock as it has a remote reservoir and adjustable damping  ( i think). The australian models didnt have remote reservors because of the battery box location left no where for the reservoir to be mounted so we missed out on the better shock.
Offline frostype400
Re: PE 175
« Reply #37 on: November 14, 2008, 09:51:01 pm »
Yes got the seat cover from him cant tell its not origanal its that good :)  jc of course it would be better with a modern shocker dont forget the 175 is a lot lighter and if you stiffened the rear suspension i reckon it would be a rocket a 250 in that frame then with maybe larger rear wheel and stiffer suspension would be something pretty good too... :)
1971 tm400 and PE's
JC14
Re: PE 175
« Reply #38 on: November 14, 2008, 09:57:33 pm »
there wouldnt be any new shocks made for my bike though...will there? what shocks would fit
Offline frostype400
Re: PE 175
« Reply #39 on: November 14, 2008, 09:59:08 pm »
Yes there would you can just take your shocker into any bike shop they will measure it eye to eye and get one the correct length i got my shocks that way its easy :)
1971 tm400 and PE's
Re: PE 175
« Reply #40 on: November 14, 2008, 10:04:57 pm »
this place maybe could do it. they make mono shocks
http://www.hagonoz.com.au/HagShocks2.htm
also this place
http://www.progressivesuspension.com/
also you could get an ohlins,Reiger,YSS or technoflex shock
i heard of somone fitting an RM shock but cant remember what year.
do you want that article about how to fit a 250 to a 175 floater frame? if so let me know.
you can also update the internal valving and fit an aftermarket spring. getting a stiffer spring will be easy
« Last Edit: November 14, 2008, 10:07:36 pm by LWC3077 »
JC14
Re: PE 175
« Reply #41 on: November 14, 2008, 10:07:24 pm »
i would like that article about the 250 into 175 frame thanks LWC. this bike should be realy good once its all done
Re: PE 175
« Reply #42 on: November 14, 2008, 10:08:16 pm »
ok i will email it to you on weekend. i will send you a PM
Mick
Re: PE 175
« Reply #43 on: November 14, 2008, 10:50:05 pm »
I found a bloke in NZ that sells PE seat covers plus tank covers and tool bags, has anyone here seen his stuff first hand ,  is it any good. http://www.ecologicalinvestments.com/
« Last Edit: November 14, 2008, 10:56:33 pm by Mick »
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: PE 175
« Reply #44 on: November 14, 2008, 10:57:08 pm »
Yes, his stuff is very good.
Ban BLACK rims NOW
