Author Topic: YZ125F question  (Read 2107 times)
klxNev
YZ125F question
« on: October 15, 2008, 11:32:24 am »
Just wondering will the barrell and head off a 125G will fit on a 125F bottom end. Thanks.
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: YZ125F question
« Reply #1 on: October 15, 2008, 11:44:27 am »
NO the "F" is centre port exhaust and the "G" is left side port exhaust
Ban BLACK rims NOW
Re: YZ125F question
« Reply #2 on: October 15, 2008, 11:14:37 pm »
Correct. And the spacing of the studs that hold the barrel to the cases is different too.
You can fit YZ-D/E top ends, along with monoshock DT125/175 top ends, or IT175 before 1980. Or IT125.
The earlier YZ and the DT parts will both require a different exhaust pipe (or mods to make the F pipe fit).
IT125 barrell will take an unmodified F pipe.
Not sure about IT175 bits (but I think they require mods).
Apparently a YZ125E top end and pipe is the hot set-up to avoid the peakiness of the standard F.
Offline cyclegod
  • Sunny PERTH W.A
Re: YZ125F question
« Reply #3 on: October 16, 2008, 12:03:55 am »
IT175F is a bolt on fit as the barrel casting is the same, just different boring diameters for the sleeves.
Bfore the first IT125 was available (125G) it was a gun setup to convert a 175 to a 125 with a barrel swap (works for E & F models)
Ban BLACK rims NOW
