Author Topic: XR75 KO Carby Question  (Read 3212 times)
Offline Hardex
« on: October 14, 2008, 08:10:58 pm »
Hi Guys.
Can anyone tell me if the XR75 k0 had a "20" Stamped on the carby top or did they have a blank carby top I know the carbies are an 18 mill so i figure they would have a blank top but i have been told the carby i have is original but i can't understand why it has a "20" on the top?????????
Thanks.
Offline caps 999
Re: XR75 KO Carby Question
« Reply #1 on: October 14, 2008, 08:16:27 pm »
2 things this could be either a casting number or the top off a larger carby was used as i believe the slide size didnt change between the 18 and 20 mil kehin carbs
MUGEN power
Offline KB171
« Reply #2 on: October 14, 2008, 09:24:29 pm »
The K1 i've got has a 20 in a circle not stamped ,cast in raised up. pretty sure its correct.if thats any help. cheers KB
Offline Hardex
« Reply #3 on: October 15, 2008, 06:16:07 am »
Sorry i should clarify the "20" is not stamped but raised up on the carby cap ,I have another xr75 k2 carby that has nothing on the top cap at all and the same with a 81 xr80 i have so im a little lost with this one.
Offline BETRIC
« Reply #4 on: October 15, 2008, 07:29:01 am »
XR75 USE A 20MM CARB, 20 IS CAST ON THE CAP, MY CARB ALSO HAS 680A STAMPED ON THE CARB FLANGE
DELTEK, 72 MINI TRAIL, 73/4 XR75, 77/78 XR75, DG MONOSHOCK FRAME XR75, REDLINE FRAME XR75, PK RACING MONOSHOCK FRAME XR75, JWRP XR FRAME, SL70K1, 81 CR80RB, TY80A/B, YZ80A/B/D, GT50/80A, GTMX80A, 73 GTMX, GT1, COOPER MX, COOPER ENDURO,MX360A,MX250B,YZ125X MX100, 72 XL250, TC100,TL125, TY250C,IT250J
Offline Hardex
« Reply #5 on: October 15, 2008, 06:50:03 pm »
Thanks for that Guys it will get me going again.Cheers ;D
« Reply #6 on: October 15, 2008, 07:09:20 pm »
I have a couple of 680a carbies , one has the raised 20 the other not.............. :D Use the one with 20 on it seems to ring a memory bell on the Little XRs :)
