Author Topic: 250 C Forks  (Read 8829 times)
YSS
Re: 250 C Forks
« Reply #15 on: October 14, 2008, 08:19:51 pm »
Its not a standard wiper seal with a metal base . Its a bit like the XR wpers but only 36.
Re: 250 C Forks
« Reply #16 on: October 14, 2008, 08:29:11 pm »
whats the dimensions? 36 X???
could be similar to a PE/KYB wiper? they dont have metal base
also All BALLS sell wiper kits. try their website
http://www.goallballs.com/home.asp hmmm maybe not, looks like they only have seals. im sure they used to have wipers
« Last Edit: October 14, 2008, 08:31:52 pm by LWC3077 »
YSS
Re: 250 C Forks
« Reply #17 on: October 14, 2008, 08:40:27 pm »
Tube ID 48  leg OD 36 , did Suzuki have 36 ?
Re: 250 C Forks
« Reply #18 on: October 14, 2008, 10:13:06 pm »
yes many RM's up to 78 and all PE's up to 81 except for 1982 PE 250/400 which still used 36
i will find a PE one and take a photo  (tomorrow)and you can see if its the right sort of thing
YSS
Re: 250 C Forks
« Reply #19 on: October 14, 2008, 10:27:21 pm »
Re: 250 C Forks
« Reply #20 on: October 15, 2008, 07:02:20 pm »
I found a wiper and as soon as I grabbed it I thought this looks right and measured the OD to be 48. I then looked underneath and read KYB 36 - 46.8 and then thought the 46.8 was the OD. I fitted the wiper inside the retaining ring that holds it in the fork slider and yeah when fitted it compresses the OD into just under 47 so its not quite the 48 you need. But I was thinking it might still work if it’s just that little bit undersize? It’s only about 0.65 undersize on each side. I was a little disappointed as when the seal is free and not in the housing it measures 48 but they classify it as a 46.7 OD as that’s what it measures when it’s slightly compressed to a firm fit in the fork slider.
But surely there is plenty of guys restoring these YZ forks and must be using something??
Offline DJRacing
  • YZ125X
Re: 250 C Forks
« Reply #21 on: October 15, 2008, 07:08:38 pm »
Walter, if you still have the old fork seals, remove the little tension spring and use the old seals as dust seals/wipes. Yes I know this isnt exactly what you want but it will get you going until you can find a pair of dust seals/wipes, and at least the old seals will be hidden under the fork boots.
YSS
Re: 250 C Forks
« Reply #22 on: October 15, 2008, 10:47:35 pm »
LWC , I think that is the one , as it only has to wipe the leg and not seal on the outside . When its pressed in it should swell anyway to 48 . They are the brown ones. Where do get them ?
Thanks DJ , thats a good bush trick , but you agree , as a customer you would not pay for a fix like that ?
Thanks for your help  anyway.
Offline DJRacing
  • YZ125X
Re: 250 C Forks
« Reply #23 on: October 16, 2008, 08:03:29 pm »
Too True Walter, I didnt relise you were looking for a customer, I thought you had finally come to your senses and lost the third wheel got a yamaha.  ;)   ;D
YSS
Re: 250 C Forks
« Reply #24 on: October 16, 2008, 08:06:22 pm »
I do have a Yamaha  DJ  and it goes like a Yamaha , but its not a 250  :D
Re: 250 C Forks
« Reply #25 on: October 16, 2008, 08:15:04 pm »
the ones i got are from 80-81 PE 175/250/400 and the 82 250 and 400 and probably the same as on the enduro DR 250/500 as well.
yes they are brown and have a total height of 16mm
i would get them from Kessners in Adelaide. just ask for fork wiper seals for a 1980 PE 250
or i would get them online at www.alpha-sports.com
something is interesting here as i was told the 78/79 PE wipers are different to the 1980 onwards ones and the 78/79 ones are also NLA as well. i wonder if they are the same as the yamaha ones that are NLA? are the yamaha forks also KYB? A few guys with the 78/79 PE had to use the later PE wipers as they couldnt get the correct ones for their bikes.
YSS
Re: 250 C Forks
« Reply #26 on: October 16, 2008, 08:17:06 pm »
I will try that and let the forum know . thanks
Offline Grunter215
Re: 250 C Forks
« Reply #28 on: October 18, 2008, 09:31:17 pm »
I just got PE400 wipers from All-balls...black with no retaining ring.
YSS
Re: 250 C Forks
« Reply #29 on: October 18, 2008, 10:49:04 pm »
Do have a pic?
