Author Topic: 83/84 - KX500 Rear Shock Upgrade  (Read 16194 times)
Re: 83/84 - KX500 Rear Shock Upgrade
« Reply #15 on: October 19, 2008, 02:12:21 pm »
could only get info for late 80 onwards ohlins for KX 500 sorry. if honda or maico single shock would have been no problem
« Reply #16 on: October 19, 2008, 03:14:53 pm »
i think. i will have a look
« Reply #17 on: October 19, 2008, 03:38:24 pm »
no i checked and out of luck here sorry. my mistake, only got 81 maico specs and 83 honda CR 250/500, plus heaps of twin shock stuff.
« Reply #18 on: October 19, 2008, 04:40:13 pm »
send me a email and then it will remind me to do it. thanks
Offline BAHNZY
« Reply #19 on: October 19, 2008, 10:53:37 pm »
Walter,
Whilst rebuilding the standard shock maybe an alternative, is it a bit like polishing & chrome plating a turd? Is the best option to replace the unit with a new unit?
So the big question, what's it going to be worth?  :)
Bahnsy
Rod (BAHNZY) Bahn
YSS
« Reply #20 on: October 20, 2008, 02:35:44 am »
No thats not quit like that , there are bits on your old shock that are OK to be reused and will save you considerable money. The heart of the shock is the piston and shaft set up , so if we can replace that, you have a much better shock straight away. ( Considering that your old shaft needs rechroming anyway)
Unless you need a High Low speed Compression adjuster, this would be the most cost effective option.
« Reply #21 on: October 20, 2008, 09:54:23 pm »
If it was mine and I could not find a good used ohlins/WP etc shock for this bike I would get it rebuilt and fit a modern Race Tech gold valve (piston)
http://www.racetech.com/shopping/shopdisplayproducts.asp?id=7&subcat=5&cat=Gold+Valve+Shock+Kits+for+Dirt&L2=Shocks&L3=Shock+Valving&L4=Gold+Valve+Shock+Kits+for+Dirt&showPage=dirt
and possibly do what many companies such as White Brothers did back in the 80’s which was to bore the passages to the reservoir hose larger and fit a braided hose with a bigger ID for increased flow, and also fit a larger finned alloy remote reservoir. White Brothers called them a ‘fade free reservoir’ When they did this and modified the valving the shock was a lot better than stock but no where near as much as buying a new aftermarket one. It would be possible to either fit a modern gold Ohlins reservoir to the stock shock you have or use a combination of custom made parts and off the shelf parts. I am getting someone to make me some reservoirs that are no longer available and I will use off the shelf end caps and internal piston.
You know what will happen don’t you. You will get your stock one all re-built and good and then a good used aftermarket shock will come up on ebay specific to you bike  ;D
« Last Edit: October 20, 2008, 09:57:38 pm by LWC3077 »
« Reply #22 on: October 20, 2008, 10:39:28 pm »
Thanks for the info Walter.
Just wondering if you can build up a complete shock for the 83 model as the one I have aquired seems to be fitted with the wrong shock as it has no resevoir at all.
Offline BAHNZY
« Reply #23 on: October 23, 2008, 07:29:46 pm »
Walter,
I'm with Geoff on this one. Can you build a shock for the bike, and if so what would be a ball park figure?
Rod
Also in previous post you advised that "Techno Flex" is now YSS. When you do an E-Bay search for KX500 shocks there are truckloads of Techno Flex shocks avalable in UK. The E-Bay site goes to the point of saying that we can build a shock for you if we don't have one avalaible.
Rod (BAHNZY) Bahn
YSS
« Reply #24 on: October 23, 2008, 07:53:42 pm »
Bahnsi , Techno Flex  has become YSS  ( or in Holland also known by the name of PROMAX Racing) in 2004.  The name Techno Flex Europe has been purchased by a group of Dutchmen to restart and use the name .( We will see , making a prototype is one thing but producing ongoing new models is another)
Due to our formation of YSS  lot of shuffeling went on .  For example WP Suspension  ( my former Buisines)
was sold to WP Europe  as per 1.9.08  and now owned by KTM Holdings. I still own the name Techno FLex in Australasia, but do not use that name.
So if you still see Techno Flex shocks in England , that may well be the case , they where a top shock and are long living. Lots of the Techno Flex Expirience flowed into YSS and we like to keep that quality and performance going , just on a lot bigger scale.
YSS
« Reply #25 on: October 23, 2008, 08:08:45 pm »
PM sent
« Reply #26 on: October 23, 2008, 08:41:28 pm »
why- because they have to match my valve and hose caps i already have
YSS
« Reply #28 on: October 26, 2008, 06:13:55 pm »
Wow thats double our price  :D  Do they have an update shaft option? Because thats the key to lots of sucsessfull conversions.
« Last Edit: October 26, 2008, 06:16:20 pm by YSS »
« Reply #29 on: October 26, 2008, 06:41:02 pm »
dont ask me. as far as i am aware they are a modern hi tech piston to replace the old OEM ones
