Author Topic: IT400D Stator Specs  (Read 4095 times)
Offline yzhilly
  • Melbourne
IT400D Stator Specs
« on: September 20, 2008, 11:15:14 pm »
Hey has anyone got the specs for testing the coil resistance  and which wires  just want to check mine got no spark??? .
Viper #436
lms6201
Re: IT400D Stator Specs
« Reply #1 on: September 21, 2008, 06:52:18 am »
hi andrew , from the clymer manual , ignition coil , primary(small wire ) to ground 1.0 ohms plus or minus 10%   secondary (high tension lead) to ground 59000 ohms p/m 10% , seems to be a general spec for all models ,   the charge coils  ,  says no specs available pre 1980 , the 400 d is different but might give u a guide ,it 425  high speed winding red to blue 35 ohms p/m 10%  , low speed winding brown to black 240 ohms p/m 10%  ,pulser coil white/red  to black 4 ohms p/m 10%   the 400 from memory has one charge coil only and by looking at the wiring diagrams ,yours ( at a guess )would be the brown to black ,i had a look in the yz manual for an equavlent yz , it doesn,t show any values at all , just says replace if in doubt !  u,ll be able to check the pulser and see if u can get a value on the charge coil , i hope this helps
Offline mboddy
  • Canberra
« Reply #2 on: September 21, 2008, 07:03:08 am »
The Yamaha IT250D/400D Owner's Service Manual says the following:
1.0ohm +-10%/20degreesC
5.7Kohm +-20%/20degreesC
Vinduro Penrite Team
lms6201
« Reply #3 on: September 21, 2008, 07:07:01 am »
more info found ,it 400 d, pulser coil white to red/black 3.4 ohms p/m 10%  ignition charge coil brown to black 166ohms p/m 10%
Offline ARN
« Reply #4 on: September 21, 2008, 04:12:27 pm »
ive got a complete ignition for a 400d it your welcome to try   arno 0418396752
Offline yzhilly
  • Melbourne
« Reply #5 on: September 21, 2008, 08:03:13 pm »
Thanks for the Info boys ,yeah i have later specs but there different to the  D . Thanks for the offer Arno i will give you a ring ,  I have been riding today and i'm wont get back to it till tomorrow .
Viper #436
Offline Viper666
    • Ballarat Rovers MCC
« Reply #6 on: September 21, 2008, 08:16:36 pm »
Click on image to make bigger
« Last Edit: September 21, 2008, 08:18:16 pm by Viper666 »
Offline yzhilly
  • Melbourne
« Reply #7 on: September 21, 2008, 08:39:10 pm »
Thanks neil thats what i needed
Viper #436
