Author Topic: Early TT600 rod bearing and crank pin wanted  (Read 147159 times)
Offline ELC hunter
« on: April 03, 2025, 10:38:34 am »
Hi all would anyone know off an aussie dealer or a person that might have these parts on the shelf after rod bearing pn.93310-634K2,Rod Pin 34K-11681-00 and thrust washers 90209-34254 for an 1987 TT600.Reading there is 3 sizes for this thing as the model progressed through it life,but the parts i need are for early type.Nothing shows up on dealer access for old stock when from my yam shop.Prefer to buy au but see what might come cheers Gavin.
Re: Early TT600 rod bearing and crank pin wanted
« Reply #1 on: April 05, 2025, 12:54:08 pm »
Try this joint in WA (Wait Awhile)
http://bbimporters.com.au/
 Phone: (08) 9295 6688
or Serco in Qld if you havn't already
Offline ELC hunter
« Reply #2 on: April 07, 2025, 09:38:45 am »
Thanks will try them.
Offline Eldert
« Reply #3 on: May 04, 2025, 04:19:08 pm »
the BE pin is no longer available .  you could use a XT 500 pin . it has a smaller hole inside the pin and is about 66 gram
heavyer . you have to check of the oiling holes in the pin line up with the flywheels .
the 34 x 42 x 20 rod bearing and thrust washers you can buy from Prox racing parts .
Eldert
« Last Edit: May 04, 2025, 04:27:35 pm by Eldert »
Offline ELC hunter
« Reply #4 on: May 19, 2025, 03:04:35 pm »
Hi thanks for info will check it out have rod but pin is issue.
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
« Reply #5 on: May 21, 2025, 11:03:40 am »
Years ago I made my own to build the 88mm long stroke cranks. Use C45 steel , hard chrome it and then grind it down to the perfect size H7 or F7 (ISO tolerance ). Any good machine shop can do it for you . Warm the outer and freeze the pin to assemble .
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
Offline Wasp
    • Suspensionshop
« Reply #6 on: May 21, 2025, 11:37:10 am »
What are the dimensions ? I might still have some . XT , TT and XS did sometimes share dimensions .
Offline ELC hunter
« Reply #7 on: May 21, 2025, 03:02:41 pm »
34x42x20 is the size Im told.
Offline Wasp
    • Suspensionshop
« Reply #8 on: May 21, 2025, 03:13:06 pm »
Just checked , mine are 26 OD
Offline ELC hunter
« Reply #9 on: May 22, 2025, 11:22:26 am »
Thanks for looking
Offline sleepy
« Reply #10 on: May 23, 2025, 04:54:21 pm »
 Bikes and bits list a rod kit them. 03.2600, pin 35mm x 74. Doesn't come with any thrust washers from memory as I believe the later models did away with them and used a 2mm wider rod and bearing. They list the bigend width as 22mm. I have a second hand pin rod and bearing of the same dimensions as the Po-x listing that came out of a TT600 a few years ago and it didn't have the thrust washers.
Offline Eldert
« Reply #11 on: May 23, 2025, 07:29:25 pm »
early TT600 have a 34 mm bigend pin  and is 74 mm long
Eldert
Offline sleepy
« Reply #12 on: May 24, 2025, 09:04:15 am »
You could machine the crank wheels out to 35mm and use the later rod kit.
« Reply #13 on: June 12, 2025, 11:03:55 pm »
Yeah i know this problem. Easiest fix is what Sleepy says to do.
