Author Topic: CZ 1973 front forks set up  (Read 73064 times)
Offline Husabergpete
« on: October 04, 2024, 06:51:34 am »
Just making a record of my attempts to improve the soft front end on my 73 380.
Forks appear standard except for the addition of `top hats' at the end of the springs. The top hats where an upgrade from back in the day apparently.
30 weight oil.  170 ml per leg.  And 10mm spacer at the top of the spring, under the cap.
Feels much better in the garage tests.
Pete
Re: CZ 1973 front forks set up
« Reply #1 on: October 04, 2024, 11:48:31 am »
Pete
A lot of guys laugh at using such thick oil in suspension, in my '84 CR500 forks I would run 30wt (ISO 100 hydraulic oil) in Winter, and 40wt (ISO 150) in Summer.
« Reply #2 on: November 12, 2024, 02:15:02 pm »
I never go off a quantity in any of my forks, in both CZs 150mm from the top when compressed works well. I do have the Motox-fox replica aluminium damper rods in both bikes
« Reply #3 on: December 01, 2024, 12:17:06 pm »
Thanks Tony. will use the mm measurement in the near future.
Pete
