Author Topic: WANTED, STD piston to suit RM125M or TM125.  (Read 6320 times)
« on: October 29, 2022, 10:03:27 am »
Would anyone have a new, or very little use, standard bore (56mm) piston for sale to suit an RM125M or TM125, I have looked at the TS125 pistons but once I shorten the inlet skirt, most of the strengthening rib along the bottom of the skirt is cut away, I want to reduce the chance of cracks appearing.
Needing a piston WITHOUT the exhaust bridge lubricating holes.
Maybe aftermarket (forged?) piston might be different, if are they better in that area I will try one, thanks.
Regards, John.
« Last Edit: October 29, 2022, 10:13:21 am by John Orchard »
Offline sleepy
Re: WANTED, STD piston to suit RM125M or TM125.
« Reply #1 on: October 31, 2022, 06:38:14 pm »
Wossner do a TS125 piston which would be more robust than the original and probably by the time you buy new rings clips and pin for a Suzuki piston you will be well on the way to the price of Wossner.
« Reply #2 on: October 31, 2022, 08:26:42 pm »
Good idea, thanks.
