Author Topic: TORQUE ENGINEERING  (Read 22148 times)
Offline Dungar Pilot
TORQUE ENGINEERING
« on: August 16, 2022, 04:29:33 pm »
Hi Everyone,
Can someone on here please help identify this exhaust?  It is looking for a new home.
Thanks in advance
Offline sleepy
Re: TORQUE ENGINEERING
« Reply #1 on: August 17, 2022, 08:58:51 am »
Could be Kawasaki F11 as the others at the time had the exhaust run on the right side.
« Reply #2 on: August 17, 2022, 06:13:41 pm »
Hi Sleepy,
To be honest, I was thinking Suzuki? There are a few RL 250s in my shed and they have the exhaust port on the right but my memory tells me that was changed for the RL from the other side?
Offline sleepy
« Reply #3 on: August 18, 2022, 09:33:21 am »
It will be a Trail bike from the early seventies as that was popular back then and you could getaway with the extra noise. The TS Suzukis had the exhaust run on the right side as did the DT/RT Yamahas and the MT250 Honda. I can't think of any Euro bikes that had pipes like that and most had basic chambers anyway so for me it is Kawasaki as that is definitely a right side pipe. Pull up a google pick of an F11 and you will see the pipe layout.
« Reply #4 on: August 18, 2022, 12:15:35 pm »
Totally agree with Sleepy, Likely be Kawasaki F7/F11 and the port size will tell you what CC. From memory the only Suzuki which had LH pipe was the baby TS90. Possibly its a Euro though more likely to be Japanese to have aftermarket pipe.
« Reply #5 on: August 18, 2022, 03:11:24 pm »
Hi Everyone,
Thanks  for the help, so I have decided it is a Bighorn! ;D ;D ;D
Offline sleepy
« Reply #6 on: August 18, 2022, 04:37:59 pm »
I remember the go for the DT3 Yamaha was to buy a DT2MX head an RT3 Carb and a Bassani pipe and they would pick up about 10 MPH top seed but way to loud when you had the throttle open riding in suburban Brisbane. Maybe that why we are half deaf now.
« Reply #7 on: October 08, 2022, 09:24:03 am »
If you can find the part number stamped on it (usually on a weld on mount) then i have the app list i can check.
« Reply #8 on: October 16, 2022, 01:48:44 pm »
Hi Everyone,
OK, so I have had another look and there aren't any weld on mounts or part numbers anywhere.
Maybe your app has a list of exhausts that don't have part numbers?
Thanks for your suggestions
« Reply #9 on: October 16, 2022, 09:13:07 pm »
Not all were stamped with the numbers. From what i have seen it was later pipes made 76/77 or later.
« Reply #10 on: October 17, 2022, 09:37:09 am »
Hi Everyone,
So do you mean only the pipes made after 1976 were stamped? Does that mean that this pipe must pre-date 1976? Perhaps it is for a Bighorn?
« Reply #11 on: October 23, 2022, 12:48:45 pm »
The pipe on the kawasaki is not a Torque Engineering pipe. No '76 is just a general thing but based on what i have seen with pipes on ebay etc, it seems that the factory only started putting the part numbers on them when they were building pipes in the late 70's and for bikes that were current then. Aslo the heat sheild attachment method seems to change in later years. Early made ones had welded on nuts and used screws, later ones have welded on studs and use lock nuts. This is how my pipe is done. Its simple, if it has part number, then i can look it up in the Torque Eng. books and ID it. No part number then your stuck wit ID'ing it purely by sight and test fitting.
