Author Topic: 1977 maico clutch adjustment  (Read 53269 times)
Offline HL400
« on: February 15, 2020, 03:23:12 pm »
Hi there does any one no the starting point for the spring cup washers on a 1977 400 maico. ? and does the extra s/steel disc go  in the middle ?
Offline sleepy
Re: 1977 maico clutch adjustment
« Reply #1 on: February 15, 2020, 07:17:15 pm »
Spring washers go in pairs opposing. The extra plate can go anywhere as it is just used to get the stack height higher. Be careful that the locking washer for the center nut doesn't stop the clutch from releasing completely. If the washer isn't bent in enough into the 3 grooves the clutch center can jam against it when it is pushed in to release the clutch. The clutch needs around 1.5mm of travel from to work properly, that can be checked with the compressor after the circlip is installed.
Offline HL400
« Reply #2 on: February 16, 2020, 09:34:02 am »
Thanks for that sleepy so I am on the right track, I had the clutch to tight and did not have the 1.5mm of travel .
