Author Topic: falta parts  (Read 26657 times)
Offline Kiwi
falta parts
« on: June 27, 2019, 06:02:34 pm »
hi guys putting my 250 falta motor that i brought incomplete together and i'm missing 3 clutch dished washers and 5 of the retaining pins, piston pin circlips, anyone got spares they want to sell? also etover has a vape ignition at a reasonable price says 980 made until 74 that should fit the falta?also to confuse matters you can chose flywheel weight 2.2 std or 1.67,1.8 please message me or phone i'm based in sydney 0417688835 thanks steve
Re: falta parts
« Reply #1 on: June 27, 2019, 07:49:52 pm »
That type of ignition won't fit, the size of the taper changed with the Falta 250s. Quickest way to tell is how the flywheel is retained, a left hand thread nut is the earlier external flywheel ignition like etovar sell, a bolt in the end of the crank is the internal rotor ignition
I use wossner circlips, will need to look tomorrow to give you the part number
I should have spare washers & pins if no one closer can help
Offline Kiwi
Re: falta parts
« Reply #2 on: June 28, 2019, 08:19:49 am »
wow thanks tony mine has a 10mm head size bolt i was very close to ordering it, know where i can get the right one? thanks steve
Offline Bamford#69
Re: falta parts
« Reply #3 on: June 28, 2019, 09:30:32 am »
Hi,  I put the light ignition flywheel ,  Vape,  on my 360 SP, but spins up too quick ;too much wheelspin , so I had to get the std weight Vape  flywheel , as well , Its much easier to ride , for an  old fella .
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
Re: falta parts
« Reply #4 on: June 28, 2019, 12:41:32 pm »
Yes the VAPE are fantastic and very realistically priced. They make them in all sort of configurations . Very similar to a Kroeber but less than half the price . Easy to fit as well .
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
Re: falta parts
« Reply #5 on: June 28, 2019, 03:57:30 pm »
Contact Charlie Richardson at CR High Performance, he lists both types of ignitions for the same price of $500us. The units he lists for 125s/Faltas are PVL units. I prefer the flywheels he uses to Vape which look like the magnets are glued in place, the system I have in my 73 is from Electrexworld & it also has a smooth flywheel which is 200g heavier than standard
http://crhighperformance.com/?wpshop_product=cz-electronic-ignition-469-95
The Vape system for the model 513 that Etovar lists also says post 74 980. Wiring looks to be set up for the shark fin casing. Price is the same as the other sort
https://etovar.eu/en/cz-motocross/2670-electronic-ignition-vape-cz-513-980-motocross.html?search_query=vape&results=57&
The Wossner circlips part number is CA18, these are exactly the same as CZ used, I normally buy a few sets at a time of Bikebuzzard on eBay but the local importer may be able to get them for you as well
« Last Edit: June 28, 2019, 04:16:00 pm by tony27 »
Re: falta parts
« Reply #6 on: June 29, 2019, 11:45:11 am »
This looks to be the same system, a couple of the photos show the crankshaft type that you should have
https://www.ebay.com/itm/cz-250-cz-980-cz-513-cz-falta-cz-997-cz-125-cz-984-cz-mx-ignition-set/254273191849?hash=item3b33dcffa9:g:PwUAAOSwCkldD2XA
