Author Topic: Filing throttle slides, richer.  (Read 23850 times)
« on: May 07, 2019, 04:37:52 pm »
Anyone filed Mikuni VM throttles slides into the richer direction?  I'm thinking of filing the bottom of my VM38 slide, changing it from 2.5 to 1.5.
I found the following chart giving slide number cutaway height...
1.0 = 1/16"
1.5 = 3/32
2.0 = 2/16
2.5 = 5/32
3.0 = 3/16
3.5 = 7/32
Re: Filing throttle slides, richer.
« Reply #1 on: May 07, 2019, 05:11:04 pm »
Can be done but there is the problem that you effectively lower the needle at the same time and can also bottom out the slide on the top of the needle jet.
Better to buy a new slide.
Offline Wasp
    • Suspensionshop
« Reply #2 on: May 07, 2019, 07:09:53 pm »
Same as Sleepy said . I have played with those carbs on my triple .  I bought 1.0 slides , filled the bottom cavity with a detachable insert and kept shaving away (just on the angle of course) till it got better .
Offline OverTheHill
« Reply #3 on: May 07, 2019, 07:17:41 pm »
Yep done that & been caught out by "everything"l Possibility for the slide then to sit on top of the needle jet where it sticks up' Also a possibility that it could get past the guide pin in the side on full song then all hell can happen. Just take care that's all, & as said--best to buy a new slide. Maybe go richer on the pilot which might help the leaner cutaway in transition to the needle [or not lol]. Would have to lean off the air screw a little [maybe], but the richer jet could help via the compensating hole [one goes straight up [think that's it] & one comes off that zt an angle [which i think is for idle only] Confused -- hell i am!!.
« Reply #4 on: May 07, 2019, 07:42:59 pm »
for some reason it remnds me of the stories i heard when i was racing speedway.....apparently old timers used to remove the needle from their carb completely as speedway is wide open at all times (if you can ride)
« Reply #5 on: May 08, 2019, 12:23:27 pm »
Thanks for feedback Chaps, l will eventually buy a new slide, will test on an old slide first as l have a stack of 2.5's kicking around the shed.
« Reply #6 on: May 08, 2019, 12:29:06 pm »
l guess l can just raise the needle by the amount l file off, l will check the needle-jet fouling issue, l took 1.4mm off the bottom of the slide, l could machine a slight 'pocket' in the bottom of the slide for clearance, maybe a small trim of the NJ shroud might not make too drastic change?
« Reply #7 on: May 08, 2019, 12:41:50 pm »
l initially went larger on the PJ, then realized that my lean issue was at partial throttle, went big with NJ and small on the needle straight section, it helped, have sinced realized that slide cutaway works between PJ & NJ which l now have worked-out is my area of concern :-)
DT211 initially advised me that he runs a 1.5 slide, l should have heeded his words sooner ;-)
« Reply #8 on: May 08, 2019, 12:44:13 pm »
Same as Sleepy said . I have played with those carbs on my triple .  I bought 1.0 slides , filled the bottom cavity with a detachable insert and kept shaving away (just on the angle of course) till it got better.
Walter a triple fitted with slide stuffers (UFO?) would really rip off the bottom-end!!
Offline Wasp
    • Suspensionshop
« Reply #9 on: May 08, 2019, 01:10:29 pm »
I have seen the UFO , but what worried me  was,  the screw going up from the bottom and you could not unhook the cable end without unscrewing the insert. I made a cavity to slide the nipple sideways and can now detach the cable if need to be,  as per standard . Also being screwed from the top down will eliminate ever ,a bolt going through the engine . I started with a 1.0 , made a jig to fit the milling machine and retain the right angle and height on all 3 slides.  I ended up somewhere between 1.5 and 2.0 . It cleaned up that fluff around 2000 RPM  just before the power curve goes up rapidly  :o.
« Reply #10 on: May 08, 2019, 06:46:26 pm »
Ah cool, l might think about making my own slide filler, l had a UFO item in the VM34 on an RM125B (that won an Oz title after l sold the bike to Ted). l was so surprised how the UFO kit made a 125, with a 34 mil carb, rip off from low rpm!
I seem to remember the retaining screw coming down from inside the slide, or l'd be worried about it going into the engine. With the increase in pulse signal in the venturi, l had to halve the pilot to a #15.
« Reply #11 on: May 08, 2019, 10:21:00 pm »
Posted by: Hoony
« on: Yesterday at 07:42:59 PM » Insert Quote
HOONY
only 1 reason to take the needle out
NITRO
« Reply #12 on: May 09, 2019, 07:12:02 pm »
Posted by: Hoony
HOONY
NITRO
yeah i heard that story too, the sponge soaked in nitro in the slide and when it went to the stopper on top of carb
the nitro was released..... don't know if that one is true as where would it go as it was captive at top of carb ?????
Offline PeterC
  • Bultaco MK 11
« Reply #13 on: May 09, 2019, 08:14:34 pm »
There was the story of Bert Flood when he was getting Ginger Molloy's Bultaco for the speed record on the caller highway thought that the way to jet around a lean jetting issue caused by a leaking crank shaft seal was to totally remove the main jet.
There may have been a sniff of Methanol in the fuel
Thumbs Up!
Offline TC91
« Reply #14 on: May 15, 2019, 09:39:16 pm »
Yes Hoony. you could tell who was using that trick at Golden City. They would idle around to the start line painfully slow then holeshot easily. I recall one top liner telling me ( at the party in eaglehawk mum & dad had after the boxing night race every year, he had consumed more than a couple !!) that it was worth 1 tooth on the engine.
