Author Topic: Fuel resistant glue for bonding rubber to metal?  (Read 17949 times)
Offline jimson
  • Sanctuary point N.S.W
Re: Fuel resistant glue for bonding rubber to metal?
« Reply #15 on: January 30, 2019, 07:17:20 pm »
From memory I bought the alloy pipe pretty much the right size, cut it to length  and put it in the lathe to make a channel so a O ring could fit, but it was to tight. If you look at one of the pics theres an O ring at the top of the pipe it seats really well in when the cap is pushed on & turned. jimson
« Reply #16 on: January 30, 2019, 08:30:44 pm »
So the alloy tube is an interference fit, or soldered into the tank? and the cap locates onto the alloy tube?
Offline jimson
« Reply #17 on: January 30, 2019, 09:31:41 pm »
I've only used the alloy pipe on the lid. The opening on the fuel tank, is just from carefully removing the old locking cap. jimson
