Author Topic: Are there any good mods for Yam DT2 forks?  (Read 11590 times)
« on: December 27, 2018, 06:43:31 pm »
Does anyone know of tricks for Yam DT2 forks in making them race-ready?
Offline David Lahey
Re: Are there any good mods for Yam DT2 forks?
« Reply #1 on: December 27, 2018, 11:49:48 pm »
Cartridge emulators are available. I run Race Tech gold valves in a set of TY250 forks which like the DT2, have 34mm Kayaba fork tubes. The gold valves took ages to get set up but are quite good now.
On another trials bike with TY250 forks I have fitted aftermarket (modern) damper rods made in the UK which worked great without any setting up required. They are made of aluminium, have slightly more travel than standard (about 5mm extra) and most importantly have much better damping action than the standard damper rods provide.
I'm sure either of those methods would also make DT2 forks work better for MX.
previous pseudonym feetupfun
« Reply #2 on: December 28, 2018, 09:27:14 am »
Thanks Dave :-)  Any idea what company in the UK made the damping rods? l'd like to get some.
Offline mboddy
  • Canberra
« Reply #3 on: December 28, 2018, 10:52:23 am »
What is the inside diameter of the fork tube? You might be able to use one of these cheap valves.
https://www.mikesxs.net/yamaha-xs650-damper-valve-pr-front-forks-77-84-oem-1t3-23170-00-00.html
I have a valve here I can measure for you.
Vinduro Penrite Team
« Reply #4 on: December 28, 2018, 02:11:54 pm »
Thanks :-)  Hmmm they look a version of Goldvalve, l'll measure my forks, do you have two to sell?
Offline mboddy
  • Canberra
« Reply #5 on: December 28, 2018, 05:05:25 pm »
... do you have two to sell?
I have a pair I am not using so I suppose I could sell them to you.
« Reply #6 on: December 28, 2018, 06:40:17 pm »
Cool, l'll gets the forks apart and determine the next step. Thanks.
« Reply #7 on: December 29, 2018, 05:06:16 pm »
These will be the parts, I have the full set up in my TY250 & the difference to how the forks were is huge
http://www.yamaha-majesty.com/?product=ty250-alloy-damper-rods
