Author Topic: Ohlins XJS1300 shocks revalve possible?  (Read 13345 times)
Offline DJPresto
« on: October 24, 2018, 08:20:35 pm »
Anyone have experience re-valving road bike shocks. Of course springs will need changing but wondering if its possible to make them work?  Cheers
Offline bazza
Re: Ohlins XJS1300 shocks revalve possible?
« Reply #1 on: October 26, 2018, 08:46:50 pm »
lot of people re valve Harley Ohlins
Offline Wasp
    • Suspensionshop
« Reply #2 on: October 26, 2018, 08:51:29 pm »
They do ? Why?
Offline Tomas
« Reply #3 on: October 26, 2018, 10:21:28 pm »
Yes. You can revalve and respring. All ohlins shocks (36mm) use same internals and various shims for on road of road use. Only problem you may have is that shafts and bodies may be too short on road bike. You would have to replace bodies and shafts plus respring and revalve for MX use.
Offline bazza
« Reply #4 on: October 27, 2018, 09:24:45 am »
They do ? Why?  because walter not all can afford your shocks
Offline Wasp
    • Suspensionshop
« Reply #5 on: October 27, 2018, 04:23:30 pm »
I assume then , that you get your Harley donor base for free , then purchase new springs , shafts , needles, shims, eyelets etc to suit your chosen model , right ?
Offline Wasp
    • Suspensionshop
« Reply #6 on: October 28, 2018, 09:17:21 am »
Are there any better options for that money? $700 incl GST  for threaded preload , damping adjustable , extreme hardy steel bore , fully rebuild able, tested and used by winning teams. Made to order in Australia .I dont know of any thing cheaper that could match that price with THAT  quality  https://store.suspensionshop.org/kawasaki/mx/1970-1979.html
 Anyway back to the original question . I would like to see the outcome and end price of that project .It is always good to see what people are doing . 8)
Offline bazza
« Reply #7 on: October 28, 2018, 10:06:34 am »
Walter probably about 25 bikes here running that set up
Offline Wasp
    • Suspensionshop
« Reply #8 on: October 28, 2018, 10:16:53 am »
So they buy Harley shocks and spend more money to convert them ?
Offline Nebo
« Reply #9 on: October 28, 2018, 05:20:59 pm »
  I regards to the Yamaha Ohlins. I have been told that they are not built to the same standards as the
   Competition Models.  In saying that they can be up graded.    Depending on the aplication.
   Stacker Motorcycles or Radars Shock Service could help.
Offline Wasp
    • Suspensionshop
« Reply #10 on: October 29, 2018, 05:24:51 pm »
I assume you actually mean XJR 1300 and not XJS ?   In order to help you, can you tell us what bike you are intending them to fit to . I do have the relevant info on the XJR 1300 ( not XJS )
Offline djr
« Reply #11 on: October 30, 2018, 08:52:30 pm »
They do ? Why?
Maybe some people prefer Ohlins  shocks more than YSS shocks regardless of the price ?
Offline Wasp
    • Suspensionshop
« Reply #12 on: October 30, 2018, 09:33:41 pm »
That can be the only explanation . Thanks for the feed back djr
