Clubroom
Tech Talk
Zundapp
Topic: Zundapp (Read 8423 times)
johnmcc
Novice
Zundapp
December 26, 2017, 12:54:58 pm »
Anyone know the best place to look for engine parts / or anyone who's a guru at rebuilding a 125 Zundapp motor ?
Tossa
Re: Zundapp
December 26, 2017, 08:50:42 pm »
there are a heap of Zundapp suppliers, best ones if you can get into them are in Europe I used this one
http://www.matton.nl/shop/
you will need to right click to translate.
this facebook page is also a great help Fans of Hercules-Sachs and Zuenapps
https://www.facebook.com/groups/WORLDWIDEVINTAGE/
I had a mate who is a m/c mechanic rebuild my zundapp motor, which basically was a wreck I have as yet not finished it due to many things, everything is together and will hopefully finish early this year. I had a thread on it in the british section
http://forum.ozvmx.com/index.php?topic=21880.0
Barry
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
johnmcc
Novice
Re: Zundapp
December 26, 2017, 10:22:13 pm »
Thanks Barry
geoff
C-Grade
Re: Zundapp
December 26, 2017, 10:29:26 pm »
Time to get your finger out Bazza, were only here once, this isn't a practise session!
LWC82PE
Superstar
Re: Zundapp
December 26, 2017, 10:50:25 pm »
I get a lot of parts from here
http://www.motorrad-stemler.de/index_e.htm
Not sure if they have stuff for your model though?
johnmcc
Novice
Re: Zundapp
December 27, 2017, 07:35:47 pm »
Thanks for that , my motor is engine type 285 , model LI or LB , I know nothing about them , I'm hoping my gearbox is OK , I know I will need clutch parts , rod kit and a top end rebuild . The fun begins !
LWC82PE
Superstar
Re: Zundapp
December 27, 2017, 09:29:23 pm »
I still have this motor. Got no idea what its worth. I would like to sell it.
https://forum.ozvmx.com/index.php?topic=15245.msg152505#msg152505
Last Edit: December 27, 2017, 09:31:34 pm by LWC82PE
Clubroom
Tech Talk
Zundapp
