Author Topic: 79/80 RM400 cylinder studs  (Read 8488 times)
Offline Huck
« on: August 15, 2017, 06:55:54 pm »
Hi all, am after 6x cylinder studs for 79/80 RM400
p/n 09108-08067
Offline rocketfrog
Re: 79/80 RM400 cylinder studs
« Reply #1 on: August 15, 2017, 08:30:53 pm »
Suzuki Dealer
Offline rocketfrog
Offline rocketfrog
« Reply #3 on: August 15, 2017, 09:04:09 pm »
should be about $4-$5 ea at any Suzuki Dealer in Oz.
Offline Huck
« Reply #4 on: August 15, 2017, 10:23:22 pm »
That link is for the wrong part number.
They were never used on other bikes, only
the 79/80 RM400
All websites list as obsolete
Offline BultacoMacca
« Reply #5 on: August 16, 2017, 03:06:20 pm »
Look at Partsshark Suzuki USA website, there seem to be 3 different size studs, and all are available from suzuki aust.
Offline rocketfrog
« Reply #6 on: August 16, 2017, 04:44:42 pm »
There you go, I know that many models use the stud I referenced above but the 400 is an oddball it appears.
Send me the dimensions of an old stud if you have one and I will see what might match up.
Offline Huck
« Reply #7 on: August 16, 2017, 05:39:51 pm »
Yeh never used them on any other bike, bugger!
Here's a thread on the same issue from about 18mth ago:
http://forum.ozvmx.com/index.php?topic=39944.msg383211#msg383211
I don't have a stud that I can check, but I believe the image below to be correct
Am happy if I dont get the titanium option  8)
Offline Huck
« Reply #8 on: August 16, 2017, 05:44:41 pm »
Nope that's a fail, part 09108-08067 not available
Offline Momus
« Reply #9 on: August 17, 2017, 12:53:02 am »
Help yourself out here mate. What length do you require ? The cylinder heads can be counterbored, shorter studs may still give you 6 threads of nut engagement, longer ones are obviously no problem.
If you love it, lube it.
Offline Huck
« Reply #10 on: August 17, 2017, 01:27:01 pm »
59mm would be perfect, just like the pic above!
I'm not into machining anything out at this stage, cheers anyway.
