Author Topic: XR600 clutch cover bolt/bung  (Read 7988 times)
Offline G54B
« on: June 07, 2017, 09:00:54 pm »
I lost this bolt from my XR600 on the way to work this morning, noticed it was missing when I pulled up at the accommodation... No bolt, and it had spewed oil all over my boot and the right hand side of the bike. Replaced it with the airbox bolt from just behind the rear brake reservoir and topped up the oil, doesn't seem to have done any damage, thankfully.
My question is, is it just a bung, or does it hold something on in behind the clutch cover?
Offline yamaico
Re: XR600 clutch cover bolt/bung
« Reply #1 on: June 08, 2017, 12:18:26 am »
I'm not a Honda expert but I would be guessing that's the oil level indication bolt.
Over to you Mick D...
« Reply #2 on: June 08, 2017, 01:41:16 am »
Arh well that's just great Pete,,,,thanks mate :D
No XR600 expert,,,,,yet ;)
Dry sump,,,the oil is held in the frame to be cooled.
The way I see it,,,is that that screw is a check inspection point,,,to make sure that the twin rotor pumping system is functioning,,,
Ok,ok ok,,,the frame downtube oil reservoir is piped to the intake of one pump rotor,,,,that rotor pumps oil to the head etc,,,,to check that circuit, one simply cracks open the oil delivery banjo feed on the cyl head whilst idling,,,if if pisses out? then that side pump rotor and delivery is functioning.
Now the way I see it is that the second pump rotor is responsible for keeping that frame reservoir full by scavenging the sump oil and pumping it to the frame. Now if you undo that check screw and the oil is below the hole level,,,then all is well, that side of the pump is evacuating the sump oil and pumping it to the frame. if it is above? then the evacuation process is lazy or not working.
So with the right amount of oil added after change,,,,the correct level is below that screw and within in the high/low mark on the frame dipstick. That is after running the bike and then idling it vertical for five minutes.
Offline mick25
  • Hunter valley NSW
« Reply #3 on: June 08, 2017, 10:55:47 am »
This is where lock wire comes into play,
I drill the bung bolt heads and the m6 head bolt closest to the bung bolt then lock wire them together problem solved .
« Reply #4 on: June 08, 2017, 11:22:08 am »
Well done Mick25
This where I should have read the first post rather than just look at the flashy pink arrow and only read Yamaico's,,,,
My bad ::) :-\
