Author Topic: Linear Shock Springs assorted by Dimension  (Read 2881 times)
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
« on: April 26, 2017, 05:38:39 pm »
Finally finished the lists and uploaded them to Magento . So when you have project , even if it is  odd  or hard to get stuff , check here , it is most likely there .  Click on the pic and the complete list will appear .  If you like to order just click "buy" and enter the dimensions in the REMARK section in the checkout section. The dimension chosen , will then become the part number . Or if it is easier , just call with the part number (dimensions ) you have found on the list .This is what we stock , nothing more , nothing less. Thanks .  http://store.suspensionshop.org/springs/shock-spring-linear.html
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
