Author Topic: Piston to transfer port matching.  (Read 20243 times)
Offline Nebo
Re: Piston to transfer port matching.
« Reply #15 on: March 20, 2017, 06:00:30 pm »
    LOZZA-  What is the problem with Wossner pistons?.
                  What are the best Piston Brand or Brands ?.
Offline cemotobull
Offline Tony.Brown
« Reply #17 on: March 20, 2017, 08:13:20 pm »
I think it's best to remember that a two stroke engine is nothing more than an air pump, all of the things that take place in a two stroke engine happen in one revolution of the crankshaft, or two strokes, hence the name. Not several cycles.
With air/fuel flowing through the engine at high speed, any disruption of the flow will be to the detriment of performance, with the exception of a properly designed expansion chamber, which is designed to provide back pressure/resonance to prevent un-burnt gases going out the exhaust port instead of being burned in the combustion chamber.
Offline yamaico
« Reply #19 on: March 21, 2017, 04:00:44 pm »
Logs or rocks in a river don't stop the river flowing.
If they build up high enough they become what we call a dam - ask a beaver. They certainly affect the flow, have a look at what the water does around a log, which is the best place to catch a fish - ask a bear.
The intake charge flows in a motor dependant upon the various changes in pressure, which are gradual changes, not step changes.
Offline Daryl Jones
    • Old Bike World
« Reply #20 on: March 27, 2017, 11:23:29 pm »
Life's too short not to try to do Everything.
"First they tell you you're wrong, and they can prove it.
Then they tell you you're right, but it's not important.
Then they tell you it is important, but they knew it all along."
Charles Kettering.
« Reply #21 on: March 28, 2017, 08:18:34 am »
he needs to stop riding Hondas and get on a husky, will stop pounding his castanets on the tank! 8)
