Author Topic: 1972 yamaha dt2 mx 250  (Read 5740 times)
Offline Davy123
« on: March 05, 2017, 05:34:43 am »
what is the correct size of carb to use ?
Re: 1972 yamaha dt2 mx 250
« Reply #1 on: March 05, 2017, 11:53:21 am »
30mm .
Offline Davy123
« Reply #2 on: March 05, 2017, 08:11:31 pm »
cheers..
Offline Davy123
« Reply #3 on: March 07, 2017, 05:42:42 pm »
Also what piston and con rod kit can I use ? Does later dt stuff fit ?
Offline sleepy
« Reply #4 on: March 07, 2017, 05:58:33 pm »
I have the rod dimensions the same as 1990-98 YZ250 and Wossner do a piston that will work as well.
« Reply #5 on: March 07, 2017, 06:52:13 pm »
Any DT MX YZ up to 1977 piston and rings will fit (just check the ring gap position first )
