Author Topic: Conrod kits for cr480's  (Read 8090 times)
090
« on: August 23, 2008, 11:27:54 am »
Thought i'd throw it out there as you can't buy one from Honda any more. If anyone has been able to adapt a kit off another bike Im all ears!
downunder930
Re: Conrod kits for cr480's
« Reply #1 on: August 30, 2008, 06:28:00 am »
I believe the hot set up back in the day was to use a 10mm longer rod out of a KTM model and a spacer under the barrel. If you would like more info i can look into it more for you....
Scott
090
« Reply #2 on: August 30, 2008, 12:12:13 pm »
Yes please Scott as i have asked the same question on an elsinore site as well with no replies.
« Reply #3 on: August 30, 2008, 02:13:47 pm »
You can do the same with an '84 500 rod, but it's a total pain in the arse.
Not only do you have to get a spacer plate made up, you also have to overcome the different height in the exhaust and intake manifolds...then there is port timing.
I ended up refitting the old rod to new bigend bearings and pin, worked fine.
Quicksilver
« Reply #4 on: September 01, 2008, 08:17:32 am »
I have a crank with brand rod kit already installed. How'd that be.  ;) I wont be needing it now.
« Reply #5 on: September 01, 2008, 08:24:38 am »
evo550
if you use the spacer the same as the extra rod length the should be no difference in the port timeing as the fly wheel has the stroke not the length of the rod.my 73 cr has a 4mm spacer in it.
Quicksilver
« Reply #6 on: September 01, 2008, 10:15:16 am »
Spacers sound good but ever tried putting your up pipe back on when barrel is higher.  ???
« Reply #7 on: September 01, 2008, 11:12:09 am »
its only 4mm.this kit is a product used  in the usa with no problems. you think pipes are made with no + or - tolerences.if this was the case no one would buy the product, then the seller, Vintage elsinores would not stock something he cant sell,
Quicksilver
« Reply #8 on: September 01, 2008, 11:35:15 am »
I doubt you would have a hassle with 4mm and down pipe Jim but 10mm with up pipe seems like trouble to me.  Some of my up pipe bikes are plan in the arse getting pipe on but with a 10mm lift added to the barrel raising exhaust port id hate to be the one trying to jam pipe back on, if will it fit at all.
090
« Reply #9 on: September 01, 2008, 06:08:53 pm »
Are you saying you have a rebuilt crank to suit an 82 83 480 Drew?
I dont think that a later model CR rod would fit an 82/3 as it is a fair amount shorter than an 85/86 and even shorter than the post 88 500's.
Plus another issue being big end pin size.
Quicksilver
« Reply #10 on: September 01, 2008, 06:20:13 pm »
Yes Brad. Thats what im saying. I have a rebuild crank for 82/83.
Offline Snowy 76
« Reply #11 on: September 01, 2008, 11:27:36 pm »
G`day Quicky,thought you were playing with a 81 cr450, or are thay the same? Havn`t got some 82 crankcases in your stash have you?. all the best. Mark.
Couple of CR`s
Quicksilver
« Reply #12 on: September 04, 2008, 08:35:38 am »
Yup I have CR450's also had 2 x CR480s a while back and some bits. Here is a pic for the doubters of crank with NEW bigend and crank pin.
Sorry Mark no CR480 cases. I have mint undamaged pair of CR450 cases that will prolly go with 450 when I sell it.
« Reply #13 on: September 04, 2008, 09:17:25 am »
Quicky,
Where did you get a new rod from?
I couldn't get one for love or money.
Offline paul
« Reply #14 on: September 04, 2008, 09:26:23 am »
carnt  you resize the rod and put a bigger bearing
