Author Topic: Wanted: YZ80C/D/E parts  (Read 3652 times)
Offline ShingoDingo
« on: January 16, 2017, 10:11:30 am »
Hey all!
I'm after anything I can get my hands on for a YZ80C bottom end (Specifically 4 crankcase stud bolts, part number 90116-06139-00. Either from a YZ or TY80 will work)
The special bolts for the YZ80D top end (Part number 90179-06180. Same part from the TY80 will work too). Also on the lookout for a carb (If I can't find one I'll get a eBay replacement)
And anything frame/body wise for a YZ80E. I'm especially in need of lever perches, levers, cables, throttle assembly (If I remember correctly the kill switch was mounted on there? So that would be nice as well)
And any other parts for the any of the bike models mentioned above. If you're selling it I might be looking to buy it!
Yes, I'm pretty much building a mismatching bike intentionally, just because all these parts look like they'll come together as one bike and it is more a learning experience for myself rather than a restoration. I still hope to make it look nice, that's for sure, but it won't be by the book all the way aha
Cheers!
   -Shingo Dingo
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: Wanted: YZ80C/D/E parts
« Reply #1 on: January 16, 2017, 01:21:40 pm »
For a little inspiration  ;D
Ban BLACK rims NOW
Offline Dungar Pilot
« Reply #2 on: January 16, 2017, 04:57:42 pm »
Hi Mate,
This clutch and oil pump cover is surplus to my needs, it came to me with TY 80 parts. I am rebuilding a TY 80 and the cylinder studs protrude less than 50 mm and appear different to the ones in your other photos.
If you are interested, I am up for swapping for anything Trials related from any make or model and I also have YZ 80 parts, but from a later model than you listed, "J" I Think?
Offline ShingoDingo
« Reply #3 on: January 16, 2017, 05:05:51 pm »
Thanks Dungar Pilot, but I've already got those parts
And thank you for confirming my suspicions. I'm pretty confident when I say that the previous owner has tried to put bolts in that aren't correct. Fingers crossed he or she hasn't caused any damage
If you know anywhere that I can find some cylinder studs in Australia that would be a massive help. And thanks again for that tip about them
« Reply #4 on: January 16, 2017, 08:43:15 pm »
I think I have a Cpl of nos heads in my stash .
