Author Topic: 34 Mukuni carby for 74 CR 125m  (Read 5301 times)
Offline amj 56
« on: January 05, 2017, 09:33:33 pm »
Looking for advice or thoughts on fitting a 34 Mukuni carb to a 74 CR 125m. Interested to know how the performance was affected and what jetting specs were used.
Any advice,help is appreciated, thanks
Allan
Offline Momus
Re: 34 Mukuni carby for 74 CR 125m
« Reply #1 on: January 06, 2017, 02:24:54 pm »
Hatrick's can supply them with close jetting. 34 is on the large side for VMX r TVideability. You will need a matching air cleaner boot and manifold.
If you love it, lube it.
Offline amj 56
« Reply #2 on: January 06, 2017, 07:26:58 pm »
Thanks for your help Momus. Back in the day some guys did run the 34 Mukuni's, just wondering if it would give a performance gain over the 30 / 32 Mukuni's that guys are currently running on their CR125m's. Have spoken with Hatrick's who have been very helpful, re jetting.
Allan
Offline motomaniac
« Reply #3 on: January 07, 2017, 03:31:07 pm »
I had a 34 on my M2 backing the day. The manifold and cylinder inlet port needs to be matched up . The manifolds are still available from mikuni so Hatrick's should have them , the air boot will be a bit harder to find but they are around.
Offline Momus
« Reply #4 on: January 09, 2017, 02:56:38 pm »
Allan
l run a 30  on mine and am happy with its rideability and vastly improved resistance to loading up. It will probably go harder with a 32 or34 at the expense of power range. Fitting tip is to turn the spigot on the carby down and use the std manifgold.
« Reply #5 on: January 09, 2017, 04:56:52 pm »
30mm or 32mm is perfect for relatively standard engines. A 16mm spacer between the inlet manifold & cylinder add torque (hard word to use with a 125) & with that mod a readily available RM125A/B air boot is a perfect fit. 34 & 36's are for modified engines in the hands of guys who can use the power at 15,000rpm.
