Author Topic: YZ125X did not run fork springs?  (Read 19353 times)
Offline Brian Watson
  • First Penton in OZ
Re: YZ125X did not run fork springs?
« Reply #15 on: February 15, 2017, 04:55:28 pm »
IIRC.. when we took the springs out of the Ceriani's in my 1974 250 KTM..( looking for more travel)..we ran about 15 psi.. maybe 20 not sure.. it's been a while..!!
« Reply #16 on: February 15, 2017, 08:47:28 pm »
50 is very high though isn't it John?
50psi gave the resistance needed, KX420 springs going in now, that an 15psi until l can find some cheap .44kg/mm springs.
« Reply #17 on: February 15, 2017, 09:20:02 pm »
in the couple of bikes I have had with air forks or similar setups I can't remember running that high John?
« Reply #18 on: February 16, 2017, 11:57:56 am »
No, the YZ125X was the only bike not running fork springs, forks without springs need higher pressures, all other late 70's bikes used light springs with air assist.
« Reply #19 on: February 16, 2017, 01:31:23 pm »
Yeah its the top chamber in the canisters that runs the higher pressures, not the main one that's sealed by the fork seals.
« Reply #20 on: February 17, 2017, 09:48:16 pm »
The lower chamber runs 22.75 to 35.56 psi where as the high pressure chamber runs 45.51 to 71.11 psi on the 125x
