Author Topic: *****WANTED :-Honda CR500 1985/86 Engine Cases and a Crankshaft *****  (Read 21413 times)
090
Re: *****WANTED :-Honda CR500 1985/86 Engine Cases and a Crankshaft *****
« Reply #30 on: August 22, 2008, 05:07:23 pm »
Why did you use the 01 crank zorroz? Does it not have the fillers on the webs? Good info btw. Didn't know Serco has the spacer.Would make a crank rebuild alot cheaper using the longer rod as they are only about $90US .
BIG RED Honda CR500 1985 Engine Cases and a Crankshaft are Cactus
« Reply #31 on: August 22, 2008, 05:33:02 pm »
Yes i too am interested in the reasons behind your decision Zorroz. as a matter of interest what does the serco spacer plate cost.
« Last Edit: August 23, 2008, 02:40:47 pm by Hoony »
Offline zorroz
« Reply #32 on: August 23, 2008, 10:14:45 am »
I used the 01 crank cause I got it for nothing and I couldn't find an 85 crank for love nor money! I don't know the exact differences but it worked great as advised by local guru Dave Hall. There's heaps of good info on CR500riders. Here's a link about the spacer plate. Its Cometic that makes the plate and it works a treat.
http://cr500riders.com/cgi/yabb/YaBB.pl?num=1163907559/0
090
« Reply #33 on: August 23, 2008, 11:24:43 am »
Thanks again zorroz for the link and info about the spacer.
« Reply #34 on: August 23, 2008, 11:53:26 am »
What increase if any in cc is it? Have seen these plates on sidecar engines.
« Reply #35 on: August 23, 2008, 02:23:26 pm »
no increases in cc or performance Tim, it is purely to allow for parts availability. later model (1987 onwards) crankcases have a 5mm higher cylinder base cast into the cases compare to 85/85 model. because of this the conrod kits are different. so you can use the spacer plate on 85/86 models and the rod kit from 87 onwards.
1985 was the High compression model and each year after that honda decompressed the CR500 slightly on every model until around 1988 to make them more rideable. That is why the sidecar boys only want 85/86 models for the lightweights back then tim as they had a few more horses and it would have been very noticeable on a sidecar with the extra weight. Bill Williams and Bruce Linsdall won the 1987 1000cc aussie title in Tassie at Bryant Park Smithton on a 86 CR500 EML.
top pic is 85/86 cases lower is 87 onwards.
« Last Edit: August 23, 2008, 02:41:13 pm by Hoony »
« Reply #36 on: August 24, 2008, 12:07:19 am »
Thanks Hoony .See ya at Ravo Sunday (oops later today!!) ;) ;)
