Author Topic: ITC shock springs  (Read 11432 times)
ITC shock springs
« on: October 05, 2016, 06:27:36 pm »
I've heard that yellow ITC springs are a heavier rate than white ITC springs, can anyone confirm or dispel this please?
Offline motomaniac
Re: ITC shock springs
« Reply #1 on: October 05, 2016, 07:08:28 pm »
I heard that too Mick , can't confirm but I have a set if you want to try them out
« Reply #2 on: October 05, 2016, 07:27:14 pm »
hey mick, ive heard from plenty that they are heaps better. no idea if they are heavier. the word is they don't sit as much as the white ones, have a bit more spring. (suggests a heavier initial rate)
Offline b490
« Reply #3 on: October 05, 2016, 08:14:16 pm »
 Have the  yellow  pair  on my 83 XC 500 .
    Feel firmer than the white ones on my '83  250 & have slightly larger diameter coil as well.
    Got them here  ;   (spring rate listed on link)
  http://www.husqvarna-parts.com/catalog/item/3736874/3443083.htm
  Regards ,
                  Steve
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
« Reply #4 on: October 05, 2016, 08:58:50 pm »
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
Offline PEZBerq
  • Brisbane
« Reply #5 on: October 05, 2016, 09:11:13 pm »
e
Correct Mick. The 9mm dia wire 16 coil is the stiffest ITC direct replacement at 10% stiffer. The white springs are 8.5mm 16.5 coils
« Reply #6 on: October 05, 2016, 10:09:49 pm »
Cool, thanks guys. Need some stiffer springs and have some yellow ones here. All good.
« Reply #7 on: October 06, 2016, 11:03:00 am »
So the plot thickens. I have 2 pairs of yellow ITC springs here (untouched originals), both are 8.5mm wire thickness with the same amount of coils as the white sets I have. Interesting to say the least.  I also have a set of non progressively wound springs with 8.0 wire thickness, 13 coils. These are supposedly a heavier rating but I really am uncertain. Walters springs are a good price, I'll do some testing with what I have but it looks like I may be giving him a call.
« Last Edit: October 06, 2016, 11:08:17 am by bigk »
« Reply #8 on: October 06, 2016, 04:36:43 pm »
got a pair of itc's without springs here mick if you want to test them....
« Reply #9 on: October 06, 2016, 07:53:38 pm »
Thanks Frank, I have an extra pair of shocks to test with.
« Reply #10 on: October 06, 2016, 08:10:53 pm »
Offline PEZBerq
  • Brisbane
« Reply #11 on: October 06, 2016, 08:51:13 pm »
The 9mm progressive ITC springs have code 00180-40 L4813.
13 coil will be stiffer than 16 coil of same wire size.
Offline b490
« Reply #12 on: October 06, 2016, 09:22:10 pm »
 As fitted to my XC500
 Ohlins  P/N:  00180-40 L3210      9mm  dia  wire
  Looks to be 16 coil ;
Regards ,
                Steve
« Last Edit: October 06, 2016, 09:26:00 pm by b490 »
Offline Tony Two Times
« Reply #13 on: October 07, 2016, 12:49:29 pm »
For what it's worth I took Curnutt springs from my OR390 to Marsh Springs here in Brisbane. Said I need these but 20% stiffer. Three days and $250 from memory. Just had to paint them myself.
#66 - Fat Snail Racing.
