Author Topic: 1981 PE Head Stem Post  (Read 3993 times)
Offline PB
« on: August 16, 2008, 08:08:54 pm »
 I have an 81PE400, I have had to change the Head Stem post (Had been modified for a different front end) I got a RM post and without paying to much attention got it pressed into the bottom triple clamp. Upon installation i found it is too short??? and I can't put the orginal front end back in until I find a original post?
Help anyone Please!
As I don't have the orginal one, is there a difference in length of the posts between PE & RM
If yes, does anyone have a PE post I can purchase?
Cameron #248
Re: 1981 PE Head Stem Post
« Reply #1 on: August 16, 2008, 08:41:48 pm »
PE 250 are the same length as  PE 400 .....and yes the Rm is about 20 mm shorter .
« Reply #2 on: August 16, 2008, 09:25:43 pm »
there are plenty of PE triple clamps on ebay in buy it now section. its is no problems finding them
Offline PB
« Reply #4 on: August 17, 2008, 08:14:57 pm »
Thanks for the information and links.
« Reply #5 on: August 18, 2008, 04:08:33 pm »
Hello Bundi PB,
Does your wife know and will she LET you spend the money?
« Reply #6 on: August 18, 2008, 05:16:08 pm »
Found a complete set in my shed looks the same as first Ebay set just not quite as pretty. You want ? Tim 754 (Elmore Vic)
« Last Edit: August 18, 2008, 05:19:39 pm by Tim754 »
Offline PB
« Reply #7 on: August 18, 2008, 09:12:12 pm »
Thanks for the phone call Tim, If I don't catch you at Ravo on Sunday, i will catch up next week and come up to Elmore, if you happen to come through White Hills at all I work there and i could meet you on your way through?
Thanks for looking through your shed. I appreciate it.
Cheers Cameron
« Reply #8 on: August 18, 2008, 10:51:32 pm »
Might just have the forks somewhere too, will chuck them in if I have too for ya,  :)  Tim
« Last Edit: August 18, 2008, 10:54:05 pm by Tim754 »
Offline suzuki 400
« Reply #9 on: August 20, 2008, 10:30:54 pm »
ive got a goodish set of triple clamps  ,about 3 of them  ;D i need a front wheel /rim for my pe400/250 as a rock took a shining to it while on a ride
Offline PB
« Reply #10 on: August 26, 2008, 10:09:04 pm »
Tim
Thanks for the help, triple clamps & post fitted perfect. Front end back in and i am now all go.  :)
« Reply #11 on: August 26, 2008, 10:31:51 pm »
 :) :) :) :) :) :) ;)Great!!! enjoy. :D
