Author Topic: 81 YZ125 footpegs and brackets  (Read 6337 times)
Offline motomaniac
« on: September 24, 2016, 10:29:03 am »
 wanted yz125 h footpegs and or brackets in good condition. Thanks . MM . Melbourne
Offline rocketfrog
Re: 81 YZ125 footpegs and brackets
« Reply #1 on: September 24, 2016, 01:57:31 pm »
I have a right side footpeg assy including bracket and brake lever for something of that era. It is a steel brake lever so I think either YZ125G, YZ125H or perhaps even IT175G/H I dont know for sure what the exact fit is but I have always believed it to be from one of the models I mentioned. Maybe take the measurement between the bolt holes including the off set and I will measure it up to see if it might fit for you.
Offline motomaniac
« Reply #2 on: September 24, 2016, 08:40:52 pm »
they are stamped , 4V2 for 125 H , that's the easiest way to identify what I am after
Offline Krikey
« Reply #3 on: September 24, 2016, 11:44:29 pm »
I've got a YZ125H rh footpeg and brake.  Can post to you
Offline rocketfrog
« Reply #4 on: September 25, 2016, 08:31:38 am »
looks like Krikey has you covered, I cannot see 4V2 stamped on this part.
Offline smed
« Reply #5 on: September 25, 2016, 05:58:00 pm »
I have IT250H ones inc brackets if of any use :)
Offline motomaniac
« Reply #6 on: September 29, 2016, 10:52:38 pm »
Thanks Mate , I got some of them , wll work but quite different position.
