Author Topic: PE175T Front Brake Leaver AU Model  (Read 2448 times)
Offline michealspad
« on: September 01, 2016, 10:57:01 am »
Hi have had a search but cant find best option for front brake lever for my 1980 PE175T with correct front brake switch cut out section.  Bike is fitted with original lever post and incorporated front brake switch but has some cheap aftermarket lever fitted so brake switch not working.  Seems to be lots of listings online but looking for correct part number or options for AU model?
Re: PE175T Front Brake Leaver AU Model
« Reply #1 on: September 01, 2016, 12:47:40 pm »
Its available brand new. Get the part number from either of the following websites
Mick Hone Suzuki
CMSNL
Pure Enduro France (has PDF parts book for many PE's, i know he has 250 T so just down load that as its same as 175. Look at E24 controls which are Australian) here made it easy for you http://pureenduro.free.fr/Div/documentation/PE%20250/part%20list%20PE%20250%20T.pdf
175 too http://pureenduro.free.fr/Div/documentation/PE%20175/PART%20LIST%20%20SUZUKI%20PE175T.pdf
Lukes Onedrive has it all there http://pureenduro.azurewebsites.net/
 https://onedrive.live.com/?id=407D7EF0965D3991%211086&cid=407D7EF0965D3991
and everything you need is here too https://groups.yahoo.com/groups/PEmotorcycles
« Last Edit: September 01, 2016, 05:23:04 pm by LWC82PE »
Offline michealspad
« Reply #2 on: September 01, 2016, 03:25:29 pm »
Thanks so much for the info will take a look.  Cheers Mike
