Author Topic: YZ250H 4V3 wrecking  (Read 6878 times)
Offline Canam370
YZ250H 4V3 wrecking
« on: August 25, 2016, 05:15:29 pm »
I have available
frame $150
swingarm with chain guide $150
rear shocker. Has damping. $250
Front forks. Straight but have some rust pitting. Straight and repairable - usable in a pinch. $120
Triple clamp set. $50
Front wheel with brake plate. $100
CDI. Condition unknown $50
Rear brake pedal - alloy. $40
Airbox with filter cage and inlet boot (not rooted) $80
Engine bottom end. No clutch parts, no covers. Crank spins freely as do the gearbox shafts. No case damage from tossed chain.$300
Cylinder head. $30
Rear wheel with brake plate . Rim in good condition (negligible rot) and no broken sprocket mount lugs. $150
Frame and engine numbers match.
Located Melbourne.
« Last Edit: August 26, 2016, 10:29:51 am by Canam370 »
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
Re: YZ250H 4V3 wrecking
« Reply #1 on: August 25, 2016, 07:06:46 pm »
Mr Canan If they are 43 , I will gladly take triple clamps,  forks , axle and wheel (front wheel  ;) ) to finish a project .
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
Offline Canam370
« Reply #2 on: August 25, 2016, 07:41:19 pm »
I'll check for you tomorrow Mr Wasp!
Offline Canam370
« Reply #3 on: August 26, 2016, 11:13:13 am »
Front end sold.
