Author Topic: parting out 250j  (Read 9961 times)
Re: parting out 250j
« Reply #15 on: August 20, 2008, 04:12:30 pm »
Hello Caps,
What condition is the shock and how much?
Offline caps 999
« Reply #16 on: August 20, 2008, 09:14:02 pm »
heres the list
brand new nos swing arm $300
frame with custom bash plate mount alloy bash plate included $150
new genuine yamaha spoke set front and rear $75 ea
dg stage two muffler brand new $200
Brand new air box will also fit yz490j $200
Forks have one damaged base leg need seals the good leg has been polished up $100 set
tripples $30 set
rear hub $100
nos front number plate $150
nos radiator $120
seat no cover base n foam good $30
tank needs work $25
rear shock $100
engine currently dismanled has all new cases except barrel and centre case with numbers  crank is good gear box is good clutch basket is good barrel is .75 os with fresh bore and new wiseco piston also has good carb and boysen power reeds to complete needs bearing for bottome end and a few small bit ie bolts n gaskets engine allone ows me welll over $1000 willing to to take $700 neg
MUGEN power
Offline caps 999
« Reply #17 on: August 20, 2008, 09:50:28 pm »
if any ones intrested ill take $1800 for the lot
MUGEN power
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #18 on: August 21, 2008, 12:07:42 am »
yep Rocket, 125j bits all gone except for the brake torque arm, pedal and upper alloy engine mounts.
but the look good in my box of crap so i'm not too bothered by thier presence.
cheers!
"flat bickie"
Offline caps 999
« Reply #19 on: August 27, 2008, 10:19:56 pm »
update
heres the list
brand new nos swing arm $300sold
new genuine yamaha spoke set front and rear $75 ea rear sold
tripples $30 set
rear hub $100sold
nos radiator $120
seat no cover base n foam good $30sold
tank needs work $25
rear shock $100sold
MUGEN power
Offline caps 999
« Reply #20 on: September 12, 2008, 11:02:55 pm »
if anyones interested ill take $500 for the engine thats just covers the clutch cover and piston
MUGEN power
Offline caps 999
« Reply #21 on: September 18, 2008, 08:53:54 am »
started up loading bit onto evil bay if anyones after any thing http://search.ebay.com.au/_W0QQsassZ2267burgess
MUGEN power
