Author Topic: First Model TT350??  (Read 60062 times)
Re: First Model TT350??
« Reply #30 on: September 01, 2016, 01:08:23 pm »
sorry to butt in but I'm looking for a cylinder for a xt/tt 250 do you have one to spare? thanks
Offline Tex
« Reply #31 on: September 03, 2016, 10:28:10 pm »
I rode the little XT250 in it's last event, the River Murray Trial near Mannum on Saturday. A great ride, but a lot of deep sand which really highlighted the 250's power deficiency. The paddock sections were also full of deep whoops, which showed the folly of trying to ride a simple trail bike in these types of events.
Jeez, I reckon the bloke on the 2 valve XT250 would have done it tougher!  :o
« Reply #32 on: September 04, 2016, 08:07:07 am »
my back hurts just thinking about it 8)
« Reply #33 on: September 04, 2016, 11:18:29 am »
Nah i reckon this would have been a piece of cake for him. He finished the 24hr this year which was in very, very bad muddy wet windy conditions with only 40 solos finishing out of over 100 starters (huge list of DNF's). Just goes to prove you can finish on anything if you set your mind to it.
« Last Edit: September 04, 2016, 11:21:06 am by LWC82PE »
Offline Colin Jay
« Reply #34 on: September 04, 2016, 01:05:15 pm »
Adam (the guy on the 2 valve) is a good rider and is deceptively fast on the old girl. The only time I have been quicker through a paddock section has been on the rare occasion that he had dropped it.
« Reply #35 on: September 04, 2016, 03:37:54 pm »
bump
Offline Colin Jay
« Reply #36 on: September 04, 2016, 05:36:39 pm »
Sorry, No. I might be looking for one myself, as I have just measured the bore on the cylinder that I have and it is 4th OS and the corrosion would require a rebore to remove.
« Reply #37 on: September 04, 2016, 09:36:06 pm »
Beware over revving the TT 350, I held mine flat for too long during the 88 Mallee Rally and I had one of the cam shafts jump a tooth, took me ages to work out why it was running like shit, only worked it out after finding out a mates jumped both cams and his valves did a tap dance on the piston
« Reply #38 on: September 05, 2016, 08:26:44 am »
"Adam (the guy on the 2 valve) is a good rider and is deceptively fast on the old girl."
Impressive...imagine how fast he would be on a husky! ;)
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #39 on: September 05, 2016, 10:48:56 am »
Would that be caused by a stretched timing chain or worn adjuster Geoff? Or is it the nature of the beast?
Offline Scuberdiver
« Reply #40 on: September 05, 2016, 07:36:20 pm »
Another SA rider here i will be building up a tt350 as well over the coming summer have two in my shed 91and 94 have the 86 250 as well but its just a roller so thats the one i will be doing up  hope to do a couple of road trials next year on it  if all goes to plan  cheers jeff
« Last Edit: September 05, 2016, 07:40:48 pm by Scuberdiver »
« Reply #41 on: October 07, 2016, 05:41:50 pm »
that's ok ive managed to get a cylinder on standard bore and needs to go to 1st oversize
yep mines on 4th and its worn, but when looking I found the std twin came bore is 73mm
and the std single came bore is 75mm so does anyone know if the single cam piston can go into the twincam if anyone has an old sohc piston I would be interested in it to do a comparison
« Reply #42 on: October 07, 2016, 07:24:48 pm »
Trusting my memory:
The SOHC piston has a big ugly hump in the middle to get the compression ratio up, and is quite different to the twin cam piston.
Pics on parts list may help to confirm or deny this.
« Reply #43 on: October 08, 2016, 10:37:54 am »
I had no luck finding a high comp piston for my 350. Stock is 9:1. With a few head mods and a 20 thou shave on the head and barrel I've managed to bump compression up to about 9:8. Now I just have to tune the carbies to the head and exhaust..... I hate twin carbies on single cylinder dirt bikes as they need to be removed to make any changes. Even worse that the TT secondary is a vacuum assisted main jet!
« Reply #44 on: October 08, 2016, 11:23:47 am »
Trusting my memory:
thanks Nathan, will look into it, but would still like to have an old tt/xt single cam piston in my hot little hands please, just thinking Mill !
