Author Topic: Differences 78 /79 CR 250  (Read 12392 times)
Offline William Doe
« on: July 31, 2016, 09:59:50 am »
Probably been asked a 100 times before  ::)
What are the major differences between a 78 CR 250 and a 79 CR 250 ?
If a club ran a Pre 79 class would the 79 model be considered a flow on ?
This is a hypothetical question so i dont need under MA rule 1235556667  ::)
thanks
Offline Oldfart
Re: Differences 78 /79 CR 250
« Reply #1 on: July 31, 2016, 10:41:52 am »
Bums on seats Bill .... bring it and let them ride it. My answer is yes
Offline William Doe
« Reply #2 on: July 31, 2016, 10:52:34 am »
Thanks Stu i would for sure , im just curious what the differences are though ?
Offline smed
« Reply #3 on: July 31, 2016, 03:58:35 pm »
The lower fork legs have a different axle clamp, sidecover stickers & slightly different front sprocket cover are the visual differences :)
Offline William Doe
« Reply #4 on: July 31, 2016, 06:03:04 pm »
Thanks Smed  :)
« Reply #5 on: July 31, 2016, 07:24:08 pm »
mainly cosmetics as SMED has said - chain rollers also different - nylon as opposed to steel - not much at all really Bill - would definitely qualify as a flow on.
Offline William Doe
« Reply #6 on: August 01, 2016, 06:08:01 am »
Thanks Rosco  :)
Offline TonkaF1
« Reply #7 on: August 11, 2016, 07:18:43 pm »
From memory, the '79 had an aluminium ring/spacer on the airbox around the airfilter to carb boot. I had a look on the parts book, but can't see that showing up on it though. I know that my 79 had the aluminium ring on it's airbox.
The older I get, the faster I was. Current Bikes-78KX125,78KX250,79KX125,79KX250,83CR125
« Reply #8 on: August 11, 2016, 08:08:46 pm »
aftermarket part - still available
Offline smed
« Reply #9 on: August 11, 2016, 09:04:26 pm »
Yep, Rosco is right,  MotoX-Fox air box ring, not original ;)
Offline HL500
« Reply #10 on: August 12, 2016, 12:28:41 pm »
If you can get hold of a parts book it identifies the differences for the 1978, 79 and 80.  The Honda-Elsinore website has a download I think that you ay be able to get.
Offline motomaniac
« Reply #11 on: August 12, 2016, 05:39:39 pm »
reeds are different.
« Reply #12 on: August 12, 2016, 10:51:31 pm »
same reeds fit all 3?
Offline motomaniac
« Reply #13 on: August 12, 2016, 11:14:42 pm »
78 are thicker . Marty Moates LOP  bike ran 79 cylinder with 78 reeds for more rpm
Offline Shane W
« Reply #14 on: August 25, 2016, 12:52:44 pm »
Different in the barrels, 79 smoother power than 78... neither have great bottom end power but fun bike to ride.....
