Clubroom
Tech Talk
Cleaning old fuel out an XT500 fuel tank?
Topic: Cleaning old fuel out an XT500 fuel tank? (Read 5763 times)
DJPresto
Novice
July 18, 2016, 05:35:26 pm »
Just wanted to know if anyone has tried cleaning years of old fuel out of an aluminum fuel tank. Its got layers of lacquer type buildup and globules of resin around the fuel tap. Most loose stuff is out but there still lots stuck inside. Saw some suggestions of using vinegar and/or acetone? Any suggestions please. cheers
Triumph Speed Triple 1050, Husky XC430 1982, Husky WR240 1985, GSX1100ez, Husky CR250 1975
80-85 husky
Re: Cleaning old fuel out an XT500 fuel tank?
July 18, 2016, 05:40:14 pm »
hand full of nuts and bolts and shake the crap out of it. rinse carefully...count them before and after.
LWC82PE
Superstar
July 18, 2016, 06:48:38 pm »
I have used Septone Alibrite to clean out alloy tanks.
TTezza
B-Grade
July 19, 2016, 12:16:29 am »
Have you tried white vinegar, buy a couple of litres cheap from woollies or coles, fill tank up and let it sit for a few days
mick25
Hunter valley NSW
Reply #4 on:
July 19, 2016, 06:27:53 am »
I have seen vinegar remove rust from some rusty header pipes .
pokey
Arse .. Elbow. Know the difference
Reply #5 on:
July 19, 2016, 08:18:07 am »
varnish isnt rust so the traditional acidic or electrolysis methods dont work. carby cleaner cleans carbs up pretty damn good and dissolves all the varnish in them.
whats in carb cleaner?
Ingredient
Toluene
Acetone
Methyl Alcohol
Propane
Diacetone Alcohol
Varnish is paint so anything that thins paint will dissolve fuel varnish.
shelpi
Reply #6 on:
July 19, 2016, 02:46:08 pm »
only stuff I got to move that dark brown stuff was more 98 octain fuel
DJPresto
Novice
Reply #7 on:
July 19, 2016, 07:42:54 pm »
I'm going to give vinegar a try first then acetone if it doesn't dissolve. Cheers
Clubroom
Tech Talk
