Author Topic: '88 KX500 frame & swing arm.  (Read 6806 times)
Offline Natroy
« on: July 10, 2016, 09:45:43 pm »
I have an '88 KX500 frame and swing arm. No good for my '89. $100.
Offline roost250
Re: '88 KX500 frame & swing arm.
« Reply #1 on: July 12, 2016, 11:44:15 am »
88 frame differs from the 89?  Thanks Peter
« Reply #2 on: July 12, 2016, 02:25:48 pm »
Frame:
Shock mounting width (narrower on 88).
8mm bolts on top subframe mount (88) vs 10mm on 89.
I think the linkage mounts are narrower on an 89 vs an 88.
Swingarm:
88 has slightly different drop outs for the rear axle.
88 has a mounting tab for the plastic rear caliper protector (89 is mounted to the caliper).
Again, I'm pretty sure the 88 linkage is wider where it mounts.
Basically, if you have an 88 main frame, then you need matching 88 subframe, swing arm, linkage and shock.
Offline Natroy
« Reply #3 on: July 12, 2016, 05:50:30 pm »
Yes, they are different.
Offline roost250
« Reply #4 on: July 12, 2016, 08:24:50 pm »
LOL!   certainly are different then!  Its interestring as the mags always say that the 88 to 04 are "the same", apart from forks...
Offline davidmc
« Reply #5 on: July 29, 2016, 12:06:26 am »
I will take it.
Where are you located?
Offline Natroy
« Reply #6 on: July 29, 2016, 05:38:59 pm »
Orange, NSW.
Offline Natroy
« Reply #7 on: August 24, 2016, 11:28:53 am »
SOLD.
