Author Topic: Shed Clearout. Honda, Yamaha, Suzuki and Kwaka parts. UPDATED with more  (Read 11388 times)
Offline Krikey
The wet weather has seen me cleaning up my shed and I've discovered some more items I no longer require.  Years of collecting bits and pieces has me with boxes and boxes of parts that you might need :)  Check it out :)
84 CR250
•   Airbox, incl inlet boot, has a small crack in airbox outer $40
•   Inlet manifold, good condition $30
•   Reed Block, good condition $20
87 CR250
•   Frame and subframe. small modifications by the looks of it but good condition, $50
•   Airbox, including inlet boot, good condition, $50
•   Rear Shock, good condition, $70
•   Tank incl mounts, tap and cap, poor condition $40
•   Shrouds, 2 sets, both usable condition, $30 each set
•   Radiators, original and a bit dented around but still hold water. $20 the pair
•   Clutch cable, good condition $15
89 CR250
•   Air filter cage, good condition, $40
•   Engine gasket kit. USA Winderosa brand. Unused except for the centre case gasket. $40
•   NOS Honda 86-89 Exhaust manifold Seal (part # 18359-ks7-000). Unopened. $15
•   Tank brackets, good cond. $30 pair
•   Plastic shock stone guard (bolts to rear of airbox), some marks, good cond. $35
•   Plastic shock stone guard (bolts to rear of airbox), cracked but repairable. $10
•   Engine clutch cover, not waterpump housing, just clutch cover plate, $20
90 CR250
•   Rear wheel incl disc rotor and sprocket, good condition $80
83 XR350
•   Cylinder head, great condition but no valves. Rare item $150
•   Twin carbs, good condition, $80
•   Airbox, good condition incl inlet rubbers (twin carb), $80
•   Swing arm, good condition $50
•   Rear Shock, good condition $50
•   Pro link linkages, good condition $50
•   Rear Wheel, good condition, $80
•   Rear Brake lever, bolt and rod to brake arm incl adjustors etc, good condition, $40
87 CR125
•   Kick Start Lever, good condition, steel $75
•   CDI, works well $150
89 CR125
•   Brand new ProX con rod kit. Made in Japan. Unopened, $100
•   Kick Start Lever, good condition but some wear in pivot, alloy $60
•   Ignition, works well $150
•   CDI Box, works well $100
•   Coil, works well $40
•   Clutch rod, good cond, $15
•   Water pump gear and impeller, $50
•   Sprocket cover. Good condition, $30
•   Kick start shaft, good condition, $75
•   Crankshaft, usable condition, $100
•   Power valve cover, good cond, $40
•   Gear selector shaft, great condition, $50
83 IT250
•   Set of matching crank cases, good condition, no chain throw damage. $150
•   Cylinder head, good condition, twin plug $50
•   Gear set including gears, selector barrel, shafts etc, GC $100
•   Kick Start Shaft with gear. Excellent condition, $50
•   IT rear tail light from early model. Genuine Yamaha, $80
PE250/400 twin shock
•   Kick starter, course spline one. Fair condition with some wear in shaft, $50
•   Side Stand incl spring and bracket to bolt to frame, good condition $75
•   Genuine Suzuki Headlight (Stanley) and black surround (black are from 81-82 onwards), great condition $75
Other parts
•   YZ400D pipe, good cond, $150
•   KDX400 carby, good cond, $75
•   KDX400 Pipe, good cond, $100
•   YZ125H complete motor including kick starter, ignition etc. Turns over. Has the hard to get clutch basket you want for your 125 G motor ?, splines all good.  $500
•   YZ125G Bottom end, complete including kick starter, ignition etc.  Again, has that hard to get clutch basket.  Turns over, splines good $400
•    YZ250 G/H alloy rear brake lever, good condition, $40
•    YZ250 G/H Standard muffler, good condition, $60
•    YZ250 G/H Ignition.  Complete except coil, looks to have the plug together bits altered to aftermarket plugs,  $150
•    87 YZ80 Radiator shroud. Good condition although been partly painted black at some stage, $30
•   Rotax 125 cc Road Race motor. Type 128. Has new piston. Comes complete with ignition incl programmable CDI box and a coil. Has carbon fibre rotary disc valve. Also includes spare ignition, spare clutch basket, spare inlet manifold etc. Engine manual, Rare $2500
•   RM125 ignition, good condition, $150
•   RM125 CDI box, $100
•   RM125C2 tank, good condition, $100
•   Xl250/350 Motorsport front wheel, incl brake and axle, good cond, $50
MORE PARTS:
•   1979 KX250A5 swingarm, great condition, anodising in excellent condition, only one bush. Rare $250
•   1979 KX125A5 swingarm, great condition, slightly faded anodising, no bushes. rare $200
•   79/80/81 PE175 Alloy swingarm, good condition, $80
•   79/80/81 PE175 rear chain guide, good cond, $40
•   79/80/81 PE175 plastic chain guard, good cond, $40
•   79/80/81 PE175 axle, spacers and drive hub including brakes, good cond, $50
•   NOS TM250 71 – 75 models (also fits TS 250 71 – 81) clutch basket.  No longer available. Were nearly $300 when available, bargain at only $200
•   Tm250 Stator with coils. Good condition, $150
•   NOS RM125/250/370/400/465 front number plate. Still in packet. $50
•   Honda XR600 Forks, good cond, $150
•   Honda XR600 Triple clamps, good cond, $40
•   Honda XR600 front wheel, good cond, $80
•   Honda XR600 airbox, missing one inlet manifold. $40
•   Honda XR250 Cartridge front forks, good cond, $150
•   Honda XR250 triple clamps, good cond, $40
•   Honda XR80 side cover LH side, white, good cond, $40
•   Honda XR80 side cover LH side, white and red, good cond, $40
•   Honda XR80 side cover LH side, red and black, good cond, $40
•   NOS Honda XR80 side cover RH side, white and purple, $75
•   Genuine HDT heads and Crane Roller rockers from ADP VK Calais. Reconditioned $1500
•   Harley Davidson Softail factory exhaust mufflers. Brand new, $200
•   Harley Davidson Pillion seat back support, inches wide?, $50
Can post at your cost of course :)
North Brisbane.
« Last Edit: August 21, 2016, 08:27:26 pm by Krikey »
Offline Glen08
Re: Shed Clearout. Honda, Yamaha, Suzuki and even Kwaka parts.
« Reply #1 on: June 19, 2016, 12:08:02 pm »
Hi there.
Interested in the PE parts mate
can I get some pics please ?
zero44876596seven cheers.
Offline relfy
« Reply #2 on: June 19, 2016, 12:16:15 pm »
PM sent IT 250 gear set.
Offline ITDOG
« Reply #3 on: August 01, 2016, 08:38:41 am »
PM sent tail light IT 8)
Offline Krikey
Re: Shed Clearout. Honda, Yamaha, Suzuki and Kwaka parts. UPDATED with more
« Reply #4 on: August 21, 2016, 08:27:06 pm »
Ad updated and some more parts I located in the shed:
Offline reg
« Reply #5 on: August 21, 2016, 08:48:36 pm »
PM sent mate, re PE parts
Offline huskibul
« Reply #6 on: August 21, 2016, 09:55:06 pm »
Pm sent about rm numberplate
« Reply #7 on: August 21, 2016, 10:10:59 pm »
is this the 78/79 hub or the 80/81 hub? they are not the same.
I am after the cush drive 80/81 version (brake drum and plate)
Offline Krikey
« Reply #8 on: August 22, 2016, 08:40:00 am »
Message me your email address or phone number and I'll send you some pictures
Offline crs-and-rms
  • heaven 23
« Reply #9 on: August 23, 2016, 06:52:25 pm »
The rm front number plate what year is it im intersted
