Author Topic: Rm/pe  (Read 4274 times)
Offline steve7406
Rm/pe
« on: June 13, 2016, 07:44:10 pm »
Will the front wheel from a 1980 rm fit into a 1979 pe front end
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
Re: Rm/pe
« Reply #1 on: June 13, 2016, 07:57:47 pm »
What model RM? 130 or 150mm brake?
Yes but the 80 forks are 180mm spaced apart and older 36mm forks are 175mm. As with all Suzuki parts around this era you can assume it will fit, either with no mods or very minor mods. The gap between where the wheel fits might even be the same requiring no mods, but if its different you may need a shorter RHS spacer or maybe an older 76-77 RM/PE one but i think they are same length anyway?. The brake plates might be wider at axle point but i doubt it. if it is and its the 125 hub, then use any 130mm brake plate from any pre 80 36mm RM/PE front end. If its 150mm RM250/400 hub then use any 150mm plate from any pre 80 suzuki with 36mm forks. Slim chance the spokes will need a slight adjustment but doubt it. It will work one way or another because i am doing the same swap with some of my bikes. All this stuff interchanges pretty effortlessly.
« Last Edit: June 13, 2016, 08:12:42 pm by LWC82PE »
Offline steve7406
Re: Rm/pe
« Reply #2 on: June 13, 2016, 08:17:05 pm »
Thanks it's a mates Pe and my rm he wants a spare wheel I'll take mine to him and what it needs
2000 Yamaha WR400f
1980 Suzuki RM250t
1977 Suzuki RM125b
1975 Yamaha MX250b
1972 Yamaha dt1 250
1976 Suzuki ts 185
