Author Topic: Frankenstein dirt bikes  (Read 28787 times)
Re: Frankenstein dirt bikes
« Reply #15 on: June 10, 2016, 08:00:39 pm »
get GMC to build it without the engine mounts. at least you wont have the maico,monty and husky police on your case for using the gen frame ;) ;D  and killing another bike ;D
Offline yamaico
« Reply #16 on: June 10, 2016, 09:28:08 pm »
One of my pet ideas is a GMC 74 Maico frame with a Yamaha SC500 motor . I would use the MX360 5 speed gear set and a YZ 400 D cdi . Just thinking out loud . Iain
That would be a winner for sure Iain.
« Reply #17 on: June 11, 2016, 11:30:27 am »
thinking along a simular path with a DT360 for a pre75 sidecar that is very slowly comeing together, was looking at the YZ400F with keen interest wit its 82mm bore and 75mm stroke
SC500 95mm x 70mm
all other 400's 85 x 70  then there is the 425 and of coarse the 465 85 x 82 thinking thinking ????
Offline Tex
« Reply #18 on: June 11, 2016, 08:03:13 pm »
How many here saw the DR600-in-Husky-frame-with-PE-swingarm special at Beaufort or Tallarook vinduros? It's a ripper!
« Reply #19 on: June 12, 2016, 08:07:42 pm »
it was a cage rattler and a few bit ;D seriously, the earlier huskys were good for transplants except the chain is on the wrong side  so a flip is required. but they are big in the engine area to accommodate the 125 / 250/ 500 as required and is usually whey they are used for hybrids (the spark has gone from the original motor...). after a heap of laps (slow ones) at CD12 I can confirm the aircooled twin shock 510 is still a camel :-X
Offline Scootern29
« Reply #20 on: August 01, 2016, 05:46:21 am »
This bike is somewhat newer than 1975. I built it for the CZ World Championships here in the states back in the early 90's. It ran in the unlimited class.
« Reply #21 on: August 01, 2016, 05:12:28 pm »
Have seen that photo quite a few times, always impresses me how together it looks. If you didn't know better you'd think it left the factory like that
« Reply #22 on: August 01, 2016, 05:18:34 pm »
 those words Tony are the perfect description of a GOOD frankenbike.
Offline crash n bern
« Reply #23 on: August 01, 2016, 07:29:19 pm »
making bikes that never existed is wrong.
[/quote]
How so? Isn't that how bikes came to be in the first place.
