Author Topic: 1978 IT/YZ ignition breakdown  (Read 4073 times)
Offline cemotobull
« on: May 19, 2016, 05:07:43 pm »
Hey all,
A mate has an 1978 IT250 and it seems to run extremely rough when warmed up.
All signs point to ignition issue (possible coil break down).
He has a new CDI box which rules that out.
Is it possible to get the coils rewound in Syndey anywhere??
He has a race meet in a weeks time so he needs to get into it ASAP.
Is there any alternative to replace the coils with an aftermarket solution??
Cheers in advance!!
Offline oldyzman
  • 250 two stroke!
Re: 1978 IT/YZ ignition breakdown
« Reply #1 on: May 19, 2016, 08:31:11 pm »
Bretty
If you dont find anywhere else then I would ask there guys:
http://www.peachtreerewinds.com.au/
We used them for motor rewinds at my old work, surely if they can rewind a star / delta 3 phase motor, they can do a basic coil??
Brett
Offline fred99999au
« Reply #2 on: May 19, 2016, 10:09:30 pm »
Coil breakdown as in stator charge coil or ignition coil?
Stator charge coil has specs in the manual and should be able to be tested with a multimeter, and the ignition coil is replaceable with a generic one.
At a pinch, a megger might see if the charge coil is shagged, but I'd seek a second opinion before trying it. Should be good for winding wire.
