Author Topic: Recommended boilermakers in Perth  (Read 15079 times)
Offline peely_14
« on: May 18, 2016, 12:55:44 pm »
Can someone please recommend a good boilermaker in Perth who will assist me with some mods to my 1975 cr125m frame. I require the rear frame loop to be bent up and some small welding jobs. I have only been messed around so far. Someone who has a passion for Vintage bikes would be ideal.
Thanks, Peely!!!
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: Recommended boilermakers in Perth
« Reply #1 on: May 18, 2016, 01:30:25 pm »
Ask Ray Easson motorcycle engineering, if he can't help you directly then he might know who would.
Ban BLACK rims NOW
Offline micko
« Reply #2 on: May 18, 2016, 03:15:46 pm »
give me a ring and I can put you onto someone I know who is a frame builder in perth, 040799993ow
micko
« Last Edit: May 18, 2016, 03:18:52 pm by micko »
« Reply #3 on: May 18, 2016, 03:41:23 pm »
try Richard at Pipe King - sounds like something he could handle.
Offline Tossa
« Reply #4 on: May 18, 2016, 08:14:42 pm »
Pat Smythe, Nautilus Productions details on our website, http://vindurowa.com/ give him a call
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Offline Tomas
« Reply #5 on: May 18, 2016, 10:02:40 pm »
I would keep my frame away from a boilermaker as far as I can. Boilermakers butcher things. You should be looking for a motorcycle frame builder or so. Some one who can use more than a stick welder and oxy torch.
Offline KTM47
« Reply #6 on: May 19, 2016, 11:58:34 am »
Boilermakers do heavy fabrication where if it doesn't fit or there is a gap they get a bigger hammer or fill it with weld.
People that do lighter fabrication, motorcycle frames or even an older panel beater are what you need.
MAICOS RULE DESPITE THE FOOLS
« Reply #7 on: May 19, 2016, 12:15:16 pm »
Jeez Thomas you single handedly insulted about 6 of me mates and myself :P sure there are rough chunts in every trade and indefence to me mates who are all frame builders,sidecars, fabricators, chromoly, aluminium, stainless, mig, tig, oxy, stick and and more than you can imagine, weld up submarines and all the rest it takes to keep shit up the pointy end  ;) all good here    thats all I got to say about that
Offline peely_14
« Reply #8 on: May 21, 2016, 01:38:27 pm »
Thanks heaps fellas for the advice and contacts, I will make some phone calls!!
Offline topari
« Reply #9 on: May 21, 2016, 02:57:32 pm »
I think Geoff Morris was trained as a boilermaker.
topari
1979 IT400F, 1984 kdx200
Offline maicomc490t
« Reply #10 on: June 23, 2016, 10:50:14 am »
Well he has turned out some pretty trick well handling boilers and neat pipes !
BULTACO M49 parts wanted
Offline KTM47
« Reply #11 on: June 23, 2016, 11:28:06 am »
Yes you are right and it doesn't mean someone trained as a Boilermaker can't learn the skills to do finer work, but generally speaking a Panel Beater or even a Fitter and Turner usually has the finer skills for frame or pipe work.
« Reply #12 on: June 23, 2016, 12:58:24 pm »
i may be wrong but i think it was Grade A Sheetmetal worker that Geoff started out as. the Surgeon of Steel.
« Reply #13 on: June 25, 2016, 09:04:30 pm »
What the!
I have just been insulted, bloody boilermaker my arse
They work with 2" plate and use sledgehammers to dress things up ;D
I'm a Sheetie, we work in the finer fabrications of life and have much gooder culture skills, we are also cheaper and more useful than a jeweler ;D
