Author Topic: big bore Honda SL125 carby help  (Read 2835 times)
Offline g465b
« on: April 03, 2016, 07:26:38 pm »
can anyone help with carb size and jetting  to suit a 150 cc  with mild cam and piped SL125 being ridden by a 100kg dreamer with visions of enough power to remove skin off custard or greased stick from dogs arse .  (petrol not methanol)  thanks
Re: big bore Honda SL125 carby help
« Reply #1 on: April 03, 2016, 08:14:22 pm »
grab a carb from a ts 185, that must be close...
Offline Momus
« Reply #2 on: April 04, 2016, 01:52:12 pm »
Standard on those was a PC22  Keihin. There is a hard to find '24'  from an XL175 or the carb ftom an ATC200. Have  look on Ebay;  there are any number of sellers flogging 24/26 mm four stroke carbies for as lttle as 30 bucks. Check that any choice has adjuster screws on the correct side. If you want it to go but are not too wrried about idle quality a oval slide PWK or OKO 24 or 26 will give good power.
If you love it, lube it.
