Author Topic: Primer for Aluminum Tank  (Read 2673 times)
Offline HuskyPete
  • Huskys Only, maybe a CCM
« on: August 05, 2008, 04:05:21 pm »
I am in the process of repainting a alloy husky tank, what is the best etch primer to use.
Thanks Pete
Re: Primer for Aluminum Tank
« Reply #1 on: August 05, 2008, 09:46:32 pm »
Spies Hecker (german, good stuff!) is the only one i use. its light grey/white in colour
Maico31
« Reply #2 on: August 06, 2008, 09:15:40 pm »
Spies Hecker make a 2 part yellow etch primer which is perfect to use on the bare alloy before you use the primer filler. Glasurit and Standox make similar products and all are very good.
Offline Maicojames
« Reply #3 on: August 08, 2008, 05:46:47 am »
Decades ago, on the alloy body cars-original AC Shelby Cobras, Alloy bodied Ferraris etc, we used fisrt a DuPont Metal Prep, then the DuPont Vari Prime self etching primer. We ended up removing much of the primer coat, since we could not put plastic filler over it, and these bodies required typically wiping the whole car.
This was after we carefully stipped with chemical stripper, then buzzed clean with air da and 120 grit paper( carefully)
 They were really rough-the opposite was a Merecedes, where for whatever reason the steel panels seemed resistant to dings etc. Very little filler required on most of those. Don't even ask about a Corvette, but at least glass does not dent.
Life is suddenly very Monaro
