Author Topic: parts list for 84 500  (Read 8365 times)
Offline gus58
« on: February 06, 2016, 04:14:10 am »
I just picked up an 84 500 and need a parts list or manual. It needs a new kick return spring and I've found a couple of numbers but no year or model number to go with them, the two numbers I've found are 666 and 8174. This bike has an aluminium tank but I guess the original plastic is more desirable. Are they and the stickers available?
Re: parts list for 84 500
« Reply #1 on: February 06, 2016, 11:34:57 am »
Does it have a welded up crank case under the bottom frame rails?
Stickers are available from MXM in the UK.
They had a manual and parts list, but it was just the "83 bike's re issued, have you tried the local Maico dealers?
« Reply #2 on: February 22, 2016, 10:58:11 am »
Couple of P.M's sent
« Reply #3 on: February 22, 2016, 12:21:40 pm »
We have an Australian dealer who specialises in Maico, he has started building a very reasonably priced Maico parts
inventory since the departure of Les. Chippy has been around Maicos for a long time and is a very decent man too.
He has also listed some free on line manuals and parts lists, including a parts list for the 84SC, click below
Maico Manuals @chippy.com
The number 8174 that you have is correct, that return spring being introduced for the 83 Spider engines and then continued on for decades. Although Maico part number allocations did change in 1985.
The same identical spring was then given the part number of 108174. same spring.
The reason your bike would have an alloy tank would be because most of the original plastic tanks are melted from them
coming into contact with the top of the exhaust chamber mounted below them. Often not noticed until fuel leaked over the exhaust.
I do have a pretty good original tank fitted with MXM graphics.
I also have a very good set of engine cases.
One very underrated machine that you have bought yourself. Good luck.
Offline paul
« Reply #4 on: February 23, 2016, 09:25:11 am »
Ive got poster size. 83 engine  with parts numbers.  15 bucks and postage the about 4 foot buy 3 footi carnt put a pic on here but ill put one on the ox vmx face book page
Offline paul
« Reply #5 on: February 23, 2016, 09:38:54 am »
« Last Edit: February 23, 2016, 09:53:03 am by paul »
« Reply #6 on: February 23, 2016, 10:56:27 am »
A must get ! I got one from Paul its great  ;) parts listing and parts numbers on it
google up Zabel Engines Germany they have all the parts for 1983/84 donks used the same stuff right upto and beyond 1996 Frank Hoffman will help out with parts list
purchase the 1986 GM500 owners manual as fluck all changed and the 86 manual is an easy find
there are other manuals ive got a parts manual starts 1974 threw to 1984 keep an eye out for that as then you can see what parts are used all the way threw
