Marketplace
Wanted
35mm Ceriani forks for pre 75 (don't need triples – have them)
Topic: 35mm Ceriani forks for pre 75 (don't need triples – have them) (Read 6459 times)
Gippslander
A-Grade
Google "Ancient Greek Sculpture for Kids" 2C more
January 27, 2016, 02:44:17 pm »
Looking for a set of 35mm Ceriani's for a pre-75 bike – the ones with 7 inch travel
Already have the triples – only need the tubes, sliders and internals.
Will pay reasonable price or if you want can swap for 77 set with the longer travel
Gippslander
A-Grade
Re: 35mm Ceriani forks for pre 75 (don't need triples – have them)
February 03, 2016, 09:29:15 am »
Bump
Grunter215
B-Grade
February 20, 2016, 09:27:53 am »
PM sent
Gippslander
A-Grade
March 01, 2016, 10:37:09 am »
Bump
mick25
Hunter valley NSW
Reply #4 on:
March 01, 2016, 05:14:58 pm »
Not sure if this helps , but I see them on the vft site in the states pop up here and there ,
There's some on there now but not cheap and there's the exchange rate plus postage .
Brian Watson
First Penton in OZ
Reply #5 on:
March 01, 2016, 05:15:12 pm »
Why don't you try and shorten the travel on the one's you have.... or are they forward axle ..?
bazza
Reply #6 on:
March 01, 2016, 07:02:00 pm »
Shorten? Have them on my B44 not to bad
Once you go black you will never go back - allblacks
Embrace patina
Gippslander
A-Grade
Reply #7 on:
March 02, 2016, 01:20:25 am »
Yep could shorten them but they are for a bike I want to run at the Nationals pre 75 and I do not want to get up to Qld and have someone say "76 forks - go home"
They are not forward axle.
Look same as the pre 75's but have a rib up the front and the cast lower leg is a bit longer.
Was hoping someone would have a set to swap
Marketplace
Wanted
