Author Topic: Yamaha IT 175 J crank  (Read 2604 times)
Offline Zarro21
« on: January 04, 2016, 02:04:27 pm »
Hi just replaced the main bearings on my IT 175. But the crank is bent it is running out 1 to 2mm on the flywheel side. So i am chasing a straight crank or a complete bottom end cheers John. ps can i get the crank straightened or rebuilt? or is it stuffed once its bent.
Offline Stewart Allen
Re: Yamaha IT 175 J crank
« Reply #1 on: January 04, 2016, 07:04:23 pm »
Hammer Time  :D
CHEERS STEWART
Doing it to old things is fun
# 74 Heaven
CR125M
SL175 bitza
IT250D needs work
CR250RE Not going as yet
YZ125F
« Reply #2 on: January 04, 2016, 07:39:18 pm »
Probably just the thread on the end bent when a puller was used to get the flywheel off. It can be straightened but a small amount of runout in the thread is not a problem. Crank can be easily re-built as well. If the mains needed changing the bigend will be quite tired as well.
Offline Zarro21
« Reply #3 on: January 05, 2016, 09:03:51 am »
Thanks for the advice Sleepy. Will look into getting crank rebuilt.  Thanks for nothing Stewie, hope to see you in 2016.
